Question about Dell OptiPlex Computers & Internet
Power turns but screen stays black no
I turn on my optiplex gx 520 but screen stays in black and i get nothing else
    Sergeant:
  • 329 Answers
Try anouther screen . turn off, unplug, hold in the power button for 30 seconds, release plug in and try agin. this sometimes reset the capacitors on the board. can you hear the sound as it starts up also is there any lites on the back around the power supply?
Posted on Oct 18, 2013
  • Richard Pollock
    Richard Pollock Oct 18, 2013
    I have tried multiple monitors and yes I hear it running. On further inspection I dont any caps fried or deformed or discolored. I also have done the manual reset by holding down the power button for over the allotted time just to be safe. no clue what else it could be. It must be fried...
  • Richard Pollock
    sorry don't see any caps deformed or discolored
SOURCE: My Dell Optiplex GX 260 seems to start by itself
in the bios the default settings should be enabled , the system is more than likely set to wake on LAN if that doesnt work than you should get a priest because your DELL needs an xorcicsmm ism anti demon cleansing lol nahh seriously hit f2 at boot and set the default which is f10 depending on the model and year of the unit chk your documentation
Posted on Dec 10, 2007
  • 166 Answers
SOURCE: optiplex gx620 black screen stuck on safe mode
Look at the motherboard (mobo). Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything.
You could also try to change out the power supply if you can find another one that fits it.
Posted on Mar 11, 2009
  • 166 Answers
SOURCE: when I switch on the computer there is nothing on the screen
Do you hear anything during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. It is starting to sound like 1 of 3 things, Power supply, Video card or motherboard.
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #2: If you get sounds and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, Try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat try that.
Also take the time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The caps will need replacing to fix (not a job for an amatuer). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
Posted on Mar 25, 2009
  • 3940 Answers
SOURCE: optiplex gx 260 steady amber light - done all
Steady Amber Power LED generally indicative of a failed MB. Remove all Memory, Expansion Cards, peripheral items, if still same, replace the motherboard. If you get a Green LED with jusr RAM in system, then an expansion card or peripheral might be the issue. 95% sure it is mothebroard
Posted on Sep 15, 2009
vannamoeurn
SOURCE: Optiplex GX520 with vista
Hi dear, i have used dell optiplex GX520. when i used with winXP i can hear sound. but when i used win7 ultimate i can't hear sound.it show " the Audio service is not running ". but i turn on it all and it don't work too. please help me
Posted on Dec 27, 2012
I want a sound max audio driver for my dell optiplex gx 520 for window 7
Hi Heart44kille, Just saw your unsolved problem. Here the link to get your sound Max Audio Digital Audio driver:
www.driversforfree.com/omn_ofm_omd_dt/dell/optiplex/gx520/audio sound/drivers.asp
Oct 01, 2012 | Dell OptiPlex GX520 PC Desktop
Sir how two install a audio driver for dell optiplex gx 520?
If you go to this site, you can get all of the drivers for the Optiplex GX 520. Please make sure you select the correct version of Windows that you are running (Windows XP, Vista, or 7). Then, select "Audio" from the drop-down list, and download the driver for ADI 198x Integrated Audio.
If you're running Windows XP, you can just click here to go directly to the driver download.
Once you download the driver, just double-click the file to start the installer.
Aug 09, 2011 | Dell OptiPlex GX520 PC Desktop
I have dell optiplex gx 520, it gives no display, it gives 6 long beeps, all capsitors are in good condition.
remove all your RAM and insert 1 by 1 into the dimm slots (power on each time to see which slot is faulty)... try this for each RAM module to see which is still good
Aug 04, 2011 | Dell OptiPlex GX280 PC Desktop
Please i need your help dell optiplex gx 280 there is a very loud noise when i press the power button and the power button colour is red instead of green nothing appears on the screen
check the boards compasstors if they have a round top on them or not if they do you need new board check also the power supply as well jim look at fan on cpu if it turns or not
Apr 04, 2011 | Dell Optiplex GX280 (99301) Motherboard
My Dell Optiplex GX 520 will start but windows will not boot. I immediately get a black screen with a blinking white prompt in the upper left corner. The prompt does not respond to any key on the...
if you try re-install windows
and sure that is hardwere problem this will return to
1- ram
2- hd cable ( data - bower)
3- take off cd drive from motherboard
4- take off kb ,mouse usb cable
just power and mb and hd and turn on if need kb connect entry then tak off again
if the problem resolved plug one deviece and turn on and try and continue as that you will find the deviecc that cause this problem.
best regards
if you see that is helpeful plz vote me
Mar 29, 2011 | Dell OptiPlex GX520 PC Desktop
My computer Dell Optiplex GX 520 miss multimedia audio controller drivers. Can i get an appropriate link to dowload?
Access the manufacturer's web-site: http://support.dell.com
and enter the Dell Asset Tag (black text on a white sticker on the back of the case)
to find all the information, including device-drivers, for your specific system.
Mar 18, 2011 | Dell OptiPlex GX520 PC Desktop
My Dell OptiPlex GX 520 has frozen. It runs Windows XP. Here in the UK, we have had a cold snap in what the papers are calling "The Coldest Day". Dunno if that's got anything to do with it. Anyway, I came...
It sounds like you may be having a processor or a memory problem here. Since it's easier to change memory than processor,get a professional to change first your memory with a working one. If problem persists, then change your processor with a working to see the results. You may have to check also whether the fan sitting on your processor heat sink is working well.
All the best.
Jan 13, 2010 | Dell OptiPlex GX520 PC Desktop
Optiplex GX 260, the computer is turnibg on but
Is the power LED flashing Amber or Solid Amber? What do the diagnostic LED s on the back of the chassis indicate?
Jun 13, 2009 | Dell OptiPlex GX260 PC Desktop
Nothing works on my dell optiplex gx 270
First, are you sure the power supply is coming on? Check by placing your hand at the back of the computer where the power cord plugs in, turn on the computer and see if you feel air blowing. It sounds like your power supply died.
If you're not using a quality surge protector, you may have fried the PS. Wal-Mart sells a cheapie one that goes bad quickly. If you spend less that $39.95 on a surge protector, you're basically wasting your money.
If the power supply doesn't come on, replace it, but you'll have to purchase it from Dell because they use proprietary PS - so generic won't work.
May 25, 2009 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
