Question about Acer Computers & Internet
I was on the computer, it froze up. now I do not have a wifi connection, I went into the control panel & under internet connection there was only Broadband, and Local area Connection Broadband. I finally plugged in the Ethernet cable & I do not even have the internet connection tab now. I am unable to add a new connection also. On the lower right corner internet connection it shows my internet name but only broadband. I do have the wifi on the TV & Kindel can you help
  • 52 Answers
Hi, Restore your computer to the last restore point before it froze using system restore. This should reset the computer where everything was working properly. Hard shut downs can corrupt files and drivers. Also do a full virus scan to make sure your system is clean.
Robert
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Posted on Oct 19, 2013
5 Suggested Answers
SOURCE: Wireless internet connection problem
the cause of your problem is that you have disable the device from device manager.
you should try uninstalling it and the re-installing, but you should only try this if you got the drivers with you (they might be on the cd that they gave you when you joined them).
Posted on Jun 10, 2008
sweetyanne
  • 68 Answers
SOURCE: Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Posted on Oct 31, 2008
LaptopExpert
  • 458 Answers
SOURCE: ethernet controller for Acer Travelmate 2312
browse through the acer panam website in the drivers / service section...
Search Other TravelMate Models and Look For An Intel Chipset Driver, Download and install..
Posted on Feb 17, 2009
  • 1170 Answers
SOURCE: I got problem in networking
It is a general problem for all TOSHIBA laptops. Its pretty hard to detect toshiba's in network. Trying using another driver software after uninstalling the current one.
Posted on Mar 06, 2009
Wifi connected no internet
Good evening,
I'd have preferred if there was some more details stating your issue, but you can still make sure of the following:
1- If you're using an ADSL router, make sure that the network cable is correctly plugged in.
2- You may try to reset your network adapter, by heading to the "Network and Sharing Centre" under your Control panel, and then look for the menu allowing you to "Manage the Network adapters" in order to reset your Wifi adapter.
3- You may also have to update your Wireless driver.
If you still face the same issue, you might have to contact your network provider if you are sure that everything is supposed to be correct from your side.
Feb 12, 2018 | Internet Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
How do I find my WiFi password...
Follow these steps:-
1. Should be connected via laptop/desktop.
2. Open Control Panel -> Network & Sharing Center.
3. Click on Network Connected like in snapshot 1.
4. Now click on Wireless Properties as in snapshot 2.
5. Under Security tab -> Network Security Key is the Network password. Refer Screenshot 3.
This is what you require.
Let me know if you need any further help.
Sep 04, 2017 | Computers & Internet
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
May 26, 2017 | Fujitsu Computers & Internet
Satellite c655d-s5200: will not display available wifi connections
The RAS PPPoE driver file "raspppoe.sys" found under c:\windows\system32\drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system.
Feb 12, 2014 | Toshiba Satellite Computers & Internet
I cant connect to wifi please help
Right click on the internet icon in bottom toolbar open network and sharing set up a new network or set up a new router or access point it will then search for any internet connected devices.
Right click in bottom toolbar select toolbars desktop this will place Desktop >> in the toolbar click on >> then control panel Network and Internet , internet options all control panel all items internet options connections set up a new connection.
Make sure the never dial a connection circle is ticked.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_1
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_3
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=420860 - Issue0_5
Jul 19, 2013 | Dell Alienware Area-51 Alx Gaming Desktop...
MY LAPTOP DOES NOT CATCH ANY WIFI SIGNALS
methinks that you need to check these two items first
a. look for a physical switch along the sides of laptop(could be sure if the model number were here) and turn it on
b. open start/control panel and look for wireless icon click on that and ensure it's active
if that does not work then make sure you have one installed
start/control panel/system icon
opens panel go to device manager(should be upper left first option on list)
look for network adapters
see if wireless is listed
if it has a yellow ? mark then you need to right click to uninstall
go to top of that panel and scan for hardware changes
may need to restart computer after this segment is complete
May 25, 2012 | Computers & Internet
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
PS3 wont connect to internet
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
