Question about Kenmore 700 6972 Dryer
My push start button doesn't work. I have power, and light inside is on. It worked one and not the next. I thought it might be the switch, but that was not it. It happens no matter what setting it is on.
  • 122 Answers
If your door does not make click sound when depressed, that may be you problem. If it does it probably is your thermal fuse.
Posted on Oct 19, 2013
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
watugot
  • 290 Answers
SOURCE: first time use, not working
The door switch is not closed or the board is not sensing the door is closed.
Push in at the top of the door to make sure it is latched at the top.
This is a common problem on the HE4's that was not a problem with the HE3's. We are hearing from Kenmore and Whirlpool that a fix is coming, a different latch I think.
Even if pushing in at the top makes it work, call for service so the problem can be addressed.
Post back if you have any questions.
Posted on Nov 12, 2007
  • 2694 Answers
SOURCE: kenmore dryer 80 series model# 110.60852990. Dryer
unplug dryer remove the vent line and take off the back panel,on the left side you'll see the duct that your lint filter slides into,to the right of it around 4 inches up from floor you'll see a white thermal fuse part 3392519,check it with meter,now go back to the filter duct,take out the four screws and clean it out,bad air movement will pop the thermal fuse,then vac out the front of dryer,take out the two screws where you pull out the lint filter,get a screw driver and pop up the top lid of dryer,one side at a time,disconnect the door switch connector,take out the two 5/16 screws one on each side and pull up on front panel and vac out the inside of dryer,when you get it running,go outside and make sure the flapper is blowing fully open,if it isn't your vent line is blocked,if it's a long run i use a leaf blower and blow all the **** out of the line and then check the flapper again some of the lint can get stuck on it and it won't close correctly,clean the dryer once a year and you shouldn't have any problems,a little maintenance goes a long way
Posted on Dec 13, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 11, 2010
  • 9 Answers
SOURCE: My kenmore 400 series dryer
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Posted on Sep 23, 2010
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
I have a 2009 dodge avenger that the front passenger window goes down but it doesnt go back up. I checked power at the motor & had power going both up & down. I thought it was the motor but I...
It may be a bad Power Window Switch, if the Power Window Motor goes up and down when you ran power leads to it but doesn't work with the switch, than the switch is bad. Replace the power window switch and it should work fine.
May 04, 2011 | Dodge Avenger Cars & Trucks
Push button to start and does not start
Your problem could be with the "push to start" switch or "door" switch.
Apr 14, 2010 | Roper RES7648E Dryer
Having an intermittent electrical problem with my 1987 toyota pickup. It runs fine, but occassionally all the power to the inside of the truck (dash lights, radio, etc) will cut out and the charge light...
How many miles on the vehicle???? There is good chance that the ignition switch is not keeping contact with the start and constant power-on terminals inside.
How many miles???
Jan 15, 2010 | 1987 Toyota Pickup
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Kenmore 700 6972 Dryer Logo
143 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
