Question about ScanSoft Nuance PaperPort 11 for PC
Freezes when unstacking - ScanSoft Nuance PaperPort 11 for PC
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
Tip
Good directions. Thanks. However I tried just unplugging the washer for a few...
This advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code. The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
I hope this information is helpful.
on Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
I need to unstack my kenmore washer/dryer
On the model posted this style does not come apart. Only on the front load style can you seperate them.
let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Kenmore 98702 Stacked Washer/Dryer
Thanks I thought it might be the inlet valve, but to get access to it behind the top panel, Is there a trick to removing the panel? I have removed the three screws behind the detergent drawer but the panel...
Hi, you will need to unstack the dryer unfortunately, then remove the three screws at the back of the top washer panel and it will slide back about 2 or 3cm and up away from the unit. Then you will see how to remove the valve. Hope that answers your question. Thanks for visiting "fixya". Let me know if you require any further assistance and good luck. Macmarkus :)
Jun 17, 2010 | Asko W6021 Front Load Washer
I need to unstack my dryer not sure how
find hand book instrutionplate, or call lowes. karl
Oct 27, 2009 | Kenmore Dryers
The gasket is torn
Hello. The seal swap isn't too difficult. You may have to unstack. If the washer is on the bottom, you may be able to scoot the dryer back enough to make the repair, but the washer case is like a cabinet; each part depends on the other parts for rigidity. For this reason alone, it would be much safer without several hundred pounds above your head. I'd unstack. That said: You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --W/D--
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Remove front of LG DLE3777 Dryer
The dryer front is usually held on by two screws in the cabinet just under the top of the dryer. Yes, they'll have to be unstacked and the top on the dryer popped loose to access these screws.
Apr 04, 2009 | LG DLE3777 Electric Dryer
How to unstack a dryer
I have a Kenmore 417.69042990 stackable dryer and had a similar problem. To unstack it, in the front of the dryer there are two screws that are covered by round caps. They are easy to miss unless you look for them. Remove the caps, and the screws underneath it. Now, voila, you can lift the front of the dryer and pull as to unlock it from the two brackets in the rear of the dryer. Hope this helps... I took me and my husband over an hour to figure this out...
Nov 11, 2007 | Dryers
HOW TO UNSTACK A WASHER AND DRYER
Chainsaw, no seriously the dryer is bolted to the washer and not all of them can be unstacked. Remove the front panel of the dryer to expose the bolts holding it down. this only works if your washer is of the front loading type. if it is a top loader there should be some sort of frame the dryer is bolted to. after removing the dryer from a front load stack washer, the washer may or may not have a top panel on it
Sep 02, 2007 | Dryers
ScanSoft Nuance  PaperPort 11 for PC Logo
13 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
