Question about Singer Electronic Sewing Machine
After hearing a noise and oiling the machine the bobbin thread becomes tangled up inside the bobbin houseing unit
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Check the tension setting on the bobbin case. If it is too loose, the thread can spool out too fast/ Use good quality thread. Ensure the thread path has bee followed correctly.
Good luck
Posted on Oct 19, 2013
bargainbox
  • 1388 Answers
SOURCE: bobbin thread
that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 323 Answers
SOURCE: thread tangles around shuttle
Either the thread is not in the take up lever or it is not in the tension. Rethread the machine. Raise the presser foot and pull on the thread between the tension and take up. It should be loose. Lower the presser foot, pull on the thread between the tension and take up lever. It should be tighter. Make sure the thread is in the slot of the take up lever and pulled to the front of the lever.
sewman7
Posted on May 22, 2008
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
SOURCE: top thread gets tangled in bobbin and won't pull up like
I'm new to sewing, and I had a similar problem where the top thread went all the way around the bobbin thingy and got stuck every time--solution: the bobbin case wasn't all the way in.  The arm had to go in a slot at the top and it sort of snapped in, then it worked fine.  Maybe it will help you!
Posted on Nov 06, 2009
SOURCE: unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Posted on Nov 18, 2009
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
What causes the thread onthe under side of my machine sewn project to bunch up and become tangled?
Make sure before you close the bobbin case, that the whole piece of thread is pulled out and put towards the back of the machine, if its bunching up dont worry about it, it might just be the way the machine is. But if it is causing problems while sewing then check the bobbin thread is not tangled inside :) Hope i helped
Oct 28, 2010 | Sewing Machines
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Trying to use and bobbin keeps tangling up with loads of thread
Oil the bobbin holder. Wipe small amount of oil on outside diameter of bobbin holder. Replace.
Also try using better quality thread. Some thread is not consistent in diameter or has lots of small fibers - it will not got through the eye of the needle easily and will become tangled.
Nov 19, 2009 | Brother LS2020 Sewing Machine
Its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Aug 10, 2009 | Brother XL-3510 Mechanical Sewing Machine
Jammed
ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
Nov 19, 2007 | Singer 1116 Mechanical Sewing Machine
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Oct 27, 2007 | Sewing Machines
Singer Electronic Sewing Machine Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
