Question about Argox A200 Printer
When I print a label it print ok but the roll scroll one page and the light blinks.
  • 73 Answers
It sounds to me like the label size is wrong, or more likely that the page size is wrong. Check the label settings. Make sure it doesn't have something like a separator page or maybe needs another label page behind it.
Posted on Oct 19, 2013
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
My printer is not printing test page?
hi,
Turn the printer off.
Remove labels roll an re-load it again.Make sure its correctly loaded.
Press and hold the green button.
Turn on the printer and release button after the first LED blink.
Turn it off and then on again.
Try printing now!
Hope it helps.thanks!
Sep 29, 2011 | Zebra LP 2844 Thermal Printer
Light is blinking and won't print labelsbet
If you like my solution, please give me 4-thumbs up rating.
Why is the light on the front of my Model 330 LabelWriter blinking?
There are 5 possible reasons for this:
  1. The labels are not left-justified
    • Verify that the labels are left justified and loaded properly in the LabelWriter. Click here for more information on loading the labels in the LabelWriter.
  2. There is paper dust or a piece of a label blocking the sensor
    • Take the roll of labels out of the printer and use the provided cleaning card to clean your unit. Click here for more information on using a DYMO Cleaning Card. You can also use compressed air by blowing some air along the left side of the paper path inside the printer.
  3. The labels you are using do not have the index marks properly cut out between each label
    • If the index holes are not cut cleanly, you may run into this problem. Try a different roll of labels.
  4. You are not using DYMO labels
    • If you are not using DYMO labels (or are unsure whether or not you are), please obtain a roll of DYMO labels and try to print again. DYMO labels are made specifically for our printers.
  5. The photo sensor that reads the index mark has failed
    • If this is the case, the unit will need to come in for repair. Select the Ask A Question tab at the top of this page to contact our Technical Support team. Please include the following information so that we can set up a Return Material Authorization (RMA) for you:
      • Full Name
      • Full Shipping Address (No PO boxes)
      • Phone Number
      • Date of Purchase
      • Model Number (a 5-digit number found on the bottom of your LabelWriter)
      • The 11-digit number under the barcode on the same label
      • Serial Number (located on the bottom of the printer, starting with "S/N" -- it also contains a dash after the first five numbers)
      • If your unit is out of warranty (beyond 2 years from the original date of purchase), please provide us with a method of payment (including expiration date, if using a credit card). The cost to repair your unit is either $75, which includes UPS Ground return shipping, or $90 for UPS Next Day Air return shipping. Please let us know which return method you desire.
Aug 04, 2011 | Dymo LabelWriter 330 Thermal Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
I have a Zebra Stripe 600. I am trying to print a
Ok, when you say continuous...do you mean it is a roll of label material that does not have gaps in between? If it has gaps...it is NOT a continuous label and you probably have the driver settings set as continuous feed and not gap as it should be....
Call BarcodeWarehouse.biz - they will help you with any problems you have!
Aug 03, 2009 | Zebra Stripe Thermal Label Printer
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Color calibration
You may first want to replace the magenta, but then do this.
  1. Press the Down Arrow and scroll to Troubleshooting.
  2. Press OK.
  3. Press the Down Arrow and scroll to Print Quality Problems.
  4. Press OK.
  5. Press the Down Arrow and scroll to Calibrate Colors.
  6. Press OK.
  7. Scroll to the Tutorial Page using the Down Arrow or Up Arrow key.
  8. Press OK to print this page.
Dec 07, 2007 | Xerox Phaser 6250DP Laser Printer
Argox A200 Printer Logo
82 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
