Question about Asko Dishwashers
My asko dishwasher is falling forward when either basket is pulled out.
  • 351 Answers
SOURCE: asko d3530 dishwasher
theres two plastic clips at the front of the rails,turn them to the side and the basket will come out
Posted on Mar 02, 2008
  • 10 Answers
SOURCE: Dishwasher falling forward
Open the door and look up at the leading edge of the dishwasher..you should see two metal eyelets that may or may not need to be bent up or swung into position. Take two sheetrock screws and screw one into each eyelet up into the underneath of your countertop that will hold it in place
Posted on Oct 05, 2009
  • 530 Answers
SOURCE: the door to the dishwasher is very hard to close.
sounds like one or both of your door links are broken check your hinges. you should ahave a large spring and a piece of rope that attaches to the door. let me know if this helps you
Posted on Jan 05, 2010
Macmarkus
  • 2605 Answers
SOURCE: replace upper basket and bearings on Asko
Welcome to FixYa.
Yes the upper rack is pretty straight forward, but the bearings are tricky.
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
1d854c5.jpg and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
The trick now is to install the balls into the holders first...
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done.
Thanks for visitng "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
Posted on Sep 23, 2010
Macmarkus
  • 2605 Answers
SOURCE: d1776 asko dishwasher upper basket
Hello, welcome to fixya
i.e.
and
i.e.
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Posted on May 16, 2011
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
I have a Asko D3530 and the top basket isn't washing properly but in my menu section it doesn't come up upper basket wash anymore?? If someone could tell me how to get that option back that wo
Keep the Program button pressed until you see wash programs like Auto or Normal displayed. This should get rid of the Lower basket program.
Manual is available from here
Jun 27, 2012 | Asko 24 in. D3530 Stainless Steel...
D 3100 continues to pump out. Program stops and program button flashes
We have just fixed our Asko 3100 dishwasher. You need to undo the screws attaching the unit to the side cabinets. Pull dishwasher out and tilt forward to drain. Put towels down as lots of water. Machine seems ok now and running on a cycle.
Nov 06, 2010 | Asko Dishwashers
Replace upper basket and bearings on Asko dishwasher 1805
Welcome to FixYa.
i.e.
1d854c5.jpg and
i.e.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Sep 23, 2010 | Asko D1876 Dishwasher
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Broken Plastic Squares
Yhey come from the upper rack bearing kit. You will find more plastic and then the bearings will fall out. It is a $30 fix. Part #1394379
Jul 01, 2008 | Asko 1385 Dishwasher
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Asko d3530 dishwasher
Feb 29, 2008 | Asko 24 in. D3530FI Built-in Dishwasher
Dishwashers Logo
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
