Question about DeVilbiss Pk17374 Pump For Excell Devilbiss Pressure Washers
The low pressure soap dispenser doesn't work. I have removed the pump manifold and it is full of rust. I do I remove the injector nipple from the pump manifold to clean it?
    Sergeant:
  • 216 Answers
To properly fix this you will need to disassemble the hose and fittings, Clean them throughly and replace the hose. Also I suggest that the fatory filter be replaced or a small screen is placed over the line again.
Many of these filters are renoved because they don't fit into soap bottles.
Posted on Oct 20, 2013
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
Soap dispenser not working
chemical injector activates only when low pressure is utilized try this remove hose from triggergun assembly with the water turned on engine off allow water to free flow out of hose remove the chemical hose from the barb located at pump with a paperclip or needle insert it into the hole of barb and slowly separate the ball inside the barb you should here it siphon and try not to look directly at the port you may get sprayed once freed reinstall all back together and try again.;0;0
Aug 02, 2013 | Karcher Garden
There was a leak i undid the mottor and repaired it but some oil spilled out, now there is no leak but little pressure and mottor does not stop
A "chattering" pressure washer pump can be caused by many things. You could have a bent or damaged inlet line, or the water supply might be too low. Fixing these is simple, but checking on the water supply is critical. Never let the water supply run low for any extended period of time. Other causes of a chattering pump include water that is too hot, you may have air in the pump system or a stuck float valve. A power washer pump that is vibrating, but not chattering could be the result of air in the system or debris stuck in the valves. Catching these pressure washer problems early and knowing what causes them will save you a trip to the repair shop, especially when it comes to the low-water issue.
Troubleshooting Low Nozzle Pressure
Low nozzle pressure is a common complaint generally caused by one of the following:
1. Plugged nozzle tip.
2. Inlet screen plugged.
3. Insufficient flow in gallons per minute (not pressure) to the pump.
4. Unloader valve stuck open due to debris lodged under the check valve ball.
5. Customer use of shutoff-type quick connectors.
6. Plugged hose.
Troubleshooting Pressure Washer Soap Injector
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following:
1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed.
2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting.
3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector.
4. If you have an adjustable nozzle, be sure it is in the low pressure position(away from the gun) to draw soap.
Thanks
Apr 01, 2012 | Garden
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
How to make the soap dispenser work
1. Make sure that you are using the black quick connect nozzle supplied with your machine. If you have a vario nozzle (turns back and forth to adjust the spray pattern), you are going to want to pull out on the nozzle to get the machine to a low pressure setting.
2. If you still have an issue, take a paper clip, straighten it out and stick it into the hose nipple on the pump where your chemical hose is connected, push in and out a couple times to free up the ball and spring.
3. If it still doesn't work, take the chemical nipple assembly apart, make sure there is a o-ring, ball and spring. If one of these are missing you are going to have to order a chemical injector repair kit. If you have all the parts you can streach out the spring a little and put it back together which should make it work.
Oct 20, 2010 | Honda Garden
Soap
1. You have poor pressure coming from the pump. fix this by removing the racks from dishwasher and removing/cleaning the intake filter to the pump. It is located on the floor of the dishwasher. Use a wet vac if you have it to clean the entire area and anything that might be stuck down in the pump. you would be suprised what you find doen there. Don't be afraid to remove a few phillips screws to remove a cover to the impeller. After this all should work better/cleaner AND soap dish will be washed out too.
2. make sure dishes are not stacked to block the soap dish from water spray arms.
3. remove spray arms and clean them out, especially the spray tips. Hard objects will stick in their spray tips.
Good Luck
Jul 29, 2009 | Maytag DWU9962 Dishwasher
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Dec 13, 2008 | Price Pfister Marielle Kitchen Faucet with...
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
DeVilbiss Pk17374 Pump For Excell Devilbiss Pressure Washers Logo
66 people viewed this question
Top DeVilbiss Plumbing Experts
Paul Carew
Tom Chichester
Are you a DeVilbiss Plumbing Expert? Answer questions, earn points and help others
