Question about Saeco Intelia Focus Automatic Espresso Machine - Black
Saeco intellia display only shows in red. Though after checking, all functions are OK. Descaled it but no change. If it does not display in red it does not display anything unless you look very carefully into the display and you can barely see what it would have been.
  • LBor
    LBor Dec 24, 2013
    I have the same thing. The green LED light is not working. However, opening up the unit looks like a lot of work and risky, if you don't know what the insides look like. Does anyone know if this unit is home-serviceable for a moderately handy guy?
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Posted on Mar 24, 2009
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
Why is it stuck with "warming up" message displayed?
If everything else works, I.e the heat element is ok. Check if the machine is getting warm.
it' s most probably the boiler, that has to be descaled.
the heat element cannot reach the required temperature to dispense coffee.
in case the machine is not getting warm, the element has to be changed.
let me know if it works after de scaling.
you might have to go through the cycle a couple of times and use an adequate solution, NOT VINEGAR!
May 28, 2015 | Saeco Royal Professional Espresso Machine
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
LED not working properly
Yes, I have exactly the same problem after running the de-scale routine, we've only been using the machine for 4 months (in Melbourne where the water is soft). You can dimly make out the icons on the display and the machine works Ok. The display contrast is set correctly, yet the green images are not showing up properly while the red images do show up.
Sep 07, 2014 | Saeco Intelia HD8752
I have descaled it twice and the red light is still there
You have to press the hot water button for 10
seconds to disable the descaling
alarm.
The steam button on the left.
Feb 02, 2010 | Saeco Odea Go
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Easy red light stays on
Make sure the magnet in the water tank flow up when you fill the water tank. Look at the dregsbox and make sure you have a little pin that goes into the machine.
Best regards
/Mirran
Oct 19, 2008 | Saeco Easy Espresso Machine
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Intelia Focus Automatic Espresso Machine - Black Logo
123 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
