Question about Vector VEC1029POB Radio
Where can I buy a VEC1029POB rechargeable battery?
Can I use rechargeable batteries?
didnt specify device --rechargeable batteries are a power source like regular batteries but you can recharge them when they get low and not change them out and buy new --so unless their is a special warning on the product specifically stating no rechargeable batteries you can use them
Aug 30, 2016 | Audio Players & Recorders
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
Is there any way to keep this charged? Or is it just batteries?
It runs in 4 "AA" batteries. You can buy rechargeable batteries (we keep two sets so one is always on the charger) or you can buy a rechargeable battery pack designed specifically for this game. For my money, the rechargeable "AA's" were a far better deal, less than half the cost.
Oct 14, 2013 | LeapFrog Leap Frog Leappad Explorer Tablet
I bought a 4 pack aa nimh2700 mah brand new sit for a long time without using them now they don't charged what can i to make them work?
  • Rechargeable batteries get old and can loose effectiveness after sitting for a while. You could have a charger problem as well. If you have another charger laying around you can see if the batteries take a charge with a different charger. But, even with rechargeables, they do go stale. If you buy new rechargeables make sure they are "fresh" as buying outdated rechargeable batteries can be a waste of many as many don't work. Buy from a reputable place as well. So many rechargeables from over seas are just not worth a dang.
  • Hope this helps.
Nov 05, 2011 | Cameras
Hi, Can I use rechargeable lithium-ion batteries in my Fuji S1730 camera. Thank you. Roy.
Hi Roy,
If your camera uses normal AA or AAA batteries you will have no problems with the rechargeable batteries. If you are considering to buy rechargeable batteries always try to buy the higher mAh range batteries. The higher the mAh the longer battery power will last.
Feel free to share if this solved your question!
Regards
Nov 29, 2010 | Cameras
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Can I buy a rechargable battery pack for my vivicam 5024 or do I have to use standard AA battery's?
You can use rechargeable AAA batteries, but you'll have to charge them outside the camera. You should be able to buy rechargeable AAAs and a charger at just about any department or electronics store.
Dec 26, 2009 | Vivitar ViviCam 5024 Digital Camera
Need a charger for a Camera
Hey annah99,
The rechargeable batteries that came with your camera should be able to be replaced with any rechargeable Ni-MH AA batteries, and our Best Buy™ stores carry these batteries as well as a charger to go with them. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 26, 2008 | Samsung Digimax S630 Digital Camera
Sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty  of sellers out there.
Oct 14, 2007 | Olympus SP-350 Digital Camera
Vector VEC1029POB Radio Logo
97 people viewed this question
Top Vector Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Vector Audio Player and Recorder Expert? Answer questions, earn points and help others
