Question about 91003 Black Tire 16 By 2.0 Inches
How many inches would I gain in 8 1/2 feet on a 4 to 12 pitch roof?
    Master:
  • 492 Answers
8.5 ft is 102 inches. Divided by 12 inch run is 8.5 times 4 inch gain is 34 inches
Posted on Oct 18, 2013
How many 2x3s are needed for ceiling 10'x11'
First of all we need to know is the two by threes inches or feet on your ceiling 10 x 11 ft you need to square it 10 times 11 divide whatever your two by threes are into the feet if their feet goes into feet you're okay if not you'll have to take change the two by threes two feet or the 10 x 11 to inches in that's reasonably simple if you know your math
Oct 27, 2017 | Computers & Internet
Tip
Cb ranges in mileage.
I have experimented for many years with various antennas and gain in the frequencies 26.965 to 27.405mhz. I have found that best performances on the Citizens Band is upper channels 37 or 39. This is where the band gets quieter and more close to Fm type communicating. Performance in antenna and hearing is best here. The Antron A99 sitting just 15 feet will get you 50 miles with decent results on a cheap Cobra 19plus or Cobra 21LTD. I can tell you by fact that a Cobra 21Ltd is equal to Cobra 25Ltd's(don't let noone tell you different) Its the same board, same calibration, same wattage plus its about $15 or so dollars cheaper than. Antennas have to be set for your frequency. I have found that the 8.5 ft(102 inch) steel whip performs best at approximate Channel #37 to 40. Homemade antennas built with a 8.25 ft element and 2 8foot rods down the side(ground) with a rod crossing the bottom at 1.5 feet. In the shape of a womans skirt.( Do not let the ground "skirt" touch the pole,seperate it by plastic PVC or milk jug with trash bag ties) I got 50 to 60 miles with this homemade job I would say had a DB gain of 10dbi. I have built home antennas that outperform Antrons. To be safe though and quick to setup is Antron A99 for about $65. Antrons have already set the frequency and low SWR. !!!DO NOT TUNE ANTRON A99 - IT BREAKS INTERNALLY!!! The average range one can get is say 10 to 50 miles average(best at night 10pm to 3 am) Don't expect any better with a Superior radio and tower or linear. A linear may kick hard within 25 miles but after that it fades into low in the distance. Unless you use 10 kilowatt or 25 Kilowatts(Electric bill will increase by $300 more--who needs it) A good power Mic on a straight radio Cobra 21LTD or 25 Ltd will be better than any mid-size linear say up to 250 watts. Your radio itself has potential with antenna gain of equal 25 to 45 watts alone. Mathematically your best with a Super Antenna and Height above 35 feet, plus heavy grounding(chain link fence buried into earth 20 X 20 feet about 8 feet down(a rod 8ft also will work) or if possible a Junk car buried into earth 8-10 feet under your Antenna. Use heavy gauge thick LOWLOSS 50 ohm coax 95% shield less than 100 feet to achieve max power out. Lengths in coax are great at 9,18,27,36 up to 72 feet(No higher than needed) The old timers swear by 72 feet. Antenna Height say: 45 feet tower with 72 feet of Coax is the usual Base setup. FCC restricts antenna towers to 60 feet above ground. No more than 20 feet above your house somewhat(when attached to house roof). No need to put $10,000 dollars in a setup with no more range than others. A mobile radio(Tuned) with Antron A99 will about outdo all Base station radios. Hope this helps you. 73's to you all.
on May 04, 2011 | Radio Communications
Math Problem Help?
2 feet 8 inches is is 32 inches.
4,500 x 32 is 144,000 inches
divide it by 12 to to bring it back to feet. The answer is 12,000.
When working in feet, which have 12 inches, it is easier to bring to a single figure rather than using fractions. This is the benefit of the Metric system as everything is based on 10s and hundreds and thousands. Millimeters, Centimeters and Metres.
Jan 04, 2017 | Homework
Can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
if you are staining the edges and both sides it will work out as follows
Each flat side is roughly 5.28 square feet or 10.5 square feet total per board.
The edges add rougly another 2.4 square feet so rough answer would be 13 square feet per board.
Jul 10, 2016 | Office Equipment & Supplies
A book box 17 x 13 x 8 inches is how many cubic feet?
First get the number of cubic inches by multiplying the three value provided.
17 x 13 x 8 = 1768 cubic inches
Then determine the number of cubic inches in a cubic foot:
12 x 12 x 12 = 1728 cubic inches
Determine the value in cubic feet by dividing the number of cubic inches in the box by the number of cubic inches in a cubic foot:
1768 divided by 1728 = 1.023148148148... cubic feet
Oct 17, 2015 | Office Equipment & Supplies
How to calculate cubic feet ?
Multiply 3500 square feet by 1.5 inches.
1.5 inches is 1/8 feet, so multiplying 3500 square feet by 1/8 feet gives 437.5 cubic feet.
Sep 04, 2014 | Pure Rest Organics Shredded 100% Natural...
Cubic feet calculator
One foot is 12 inches, so 8 feet times 2 feet times 5/12 feet is 6 2/3 cubic feet (about 6.67 cubic feet).
Apr 25, 2014 | Office Equipment & Supplies
Cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Dec 09, 2008 | Electric 1/2hp 1140RPM 56 Frame 230/460V...
91003 Black Tire 16 By 2.0 Inches Logo
Top Kent Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Kent Vehicle Part and Accessory Expert? Answer questions, earn points and help others
