Question about Kyocera Mita KM-2530 Laser Printer
Gapped incomplete printing of text and pictures
Called out to look at a this machine. It is working but making splotchy copies/prints and displaying the "Time for Maintenance" on the panel. I cleaned the corona wire and the rotary scrubber sponge that contacts the drum. There are striped and blotched areas of toner baked on the drum. I know these are causing the poor print quality. Is there a safe way to clean the drum.. ie iso. alcohol or anything else.. or will this make things worse? Is there a reset to turn off the maint. display or is this a call for the BIG ONE for the warranty that must be done?
A KM 2530 that displays "Maintenance time" has done 400,000 copies with the same drum,dev. unit, fuser and transfer roller. They can run longer but these items are due to be changed and I suspect your problems will disappear after a complete Maintenance Kit is installed all at once by a qualified technician. This is not cheap but if you divide the number of copies into this cost your cost per copy is cheaper than anything else on the market. They are good machines with few problems
Posted on Dec 27, 2007
  • 56 Answers
Try this:
1. drum refreshing- set A3,or A4 paper in the multipurpose tray.(bypass) press the * (asterisk) key
on the control panel. Then select drum refreshing.Select "ON".
2. Check the Drum Cleaning blade-clean it,
Drum can be cleaned with alcolhol,if copy quality is bad after that perform several drum refresh procedures.
3.Time for maintenance is just info for customer that machine has declared maintenance interval.
Customer must check Warranty terms and conditions.
resseting time for maintenance: enter 10871087,then select U251, press start.To clear,press clear key(yellow button)
and start.After that,press stop key twice,and enter 001 and start.
4. Also I suggest to clean grid on main corona.
Posted on Nov 02, 2007
Horizontal print gaps on ml184+
The most common cause of missing sections in the letters is a bad print head. These types of printers (Dot Matrix) create the print with the print head which has a line of small pins called hammers that are activated by an electromagnet. Each pin has its own hammer. If the electromagnet fails or you have something jamming the hammer then it will not move to strike the ribbon and make the image or letter. You can get a replacement print head online for about $15.00, the part number is 50063802. Here is a picture of what the print head looks like. :
Dec 30, 2011 | OKI MICROLINE 184 Turbo Matrix Printer
"Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
  • The printer cable is loose or defective.
  • the wrong printer driver was selected.
  • The software application is malfunctioning.
  • The operating system is malfunctioning.
Have a nice day!
Oct 25, 2009 | Samsung ML 1710 Laser Printer
Incomplete Printing
It depends on the page you are trying to print. Some pages do not like printing everything on the page. What I have done is printed to PDF (with images) and then printed the PDF. You can find free PDF printers here:
Jul 12, 2009 | Office Equipment & Supplies
The (HP Descjet F2200 series ) is working ,just
There are settings that you frequently use for printing, you might want to make them the
default print settings so they are already set when you open the Print dialog box from
within your software application.
To change the default print settings
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
2. Make changes to the print settings, and click OK.
To create a printing shortcut
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Printing Shortcuts tab.
5. In the Printing Shortcuts list, click a printing shortcut.
The print settings for the selected printing shortcut are displayed.
6. Change the print settings to those you want in the new printing shortcut.
7. Click Save as and type a name for the new printing shortcut, and then click Save.
The printing shortcut is added to the list.
If you don't have a copy of the manual click on the link below and it has many more printing (how to) instructions in chapter 7 page 34
May 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My epson cx6400 printer won't print it not been use for several
I'm not sure what you mean by not printing, is it trying to print but only blank pages?
Make sure its on and the "!" is off.
Try copying first using the unit itself since this is an all in one printer. If it prints then we know its working.
If scanner is not working you can try printing without using the scanner featured on the unit. press on the setup button use the left or right arrow repeatedly and select on nozzle check then press on the color button.
If it prints but the pattern is incomplete (gaps or breaks on the lines) you can try head cleaning.
Press setup use the arrow left or right repeatedly and select on head cleaning then press on the color button then it will clean it.
Make sure that everytime you clean it you have to print on a nozzle check so that you will know that it prints properly.
If there are no gaps or breaks on the lines print on a document or picture it will give you good printouts
Feb 12, 2009 | Epson Stylus C86 InkJet Printer
Bad print outs.
You could try putting your printer through a few cleans and calibrations. If this doesnt work try changing the ink cartridges, as one may have a damaged printhead
Jan 03, 2009 | HP Officejet 6310 All-In-One InkJet...
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
Apr 20, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
Kyocera Mita KM-2530 Laser Printer Logo
135 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
