Question about NewAir AI-215SS Stainless Steel Portable Ice Maker
Water keep running .. Not stop - NewAir AI-215SS Stainless Steel Portable Ice Maker
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Water valve not closing...or sensing that there is not enough water.
There is a float switch somewhere that is stuck open. Or the water is draining as it is filling.
Posted on Oct 19, 2013
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Water keeps running from drinking spicket.
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip.
Aug 17, 2009 | Oasis P1AQ
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Constant running of water
You need a new water inlet valve. this will fix it.
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
NewAir AI-215SS Stainless Steel Portable Ice Maker Logo
123 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
L Pfaff
L Pfaff
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
