Question about frontier.com
How can I add minutes to the time of a show when taping, such as a game that may go over its intended time?
No connetion
Posted on Oct 18, 2013
Tefal 4 in 1 rice cooker - Cooking time won't go over 60min?
This is correct. It is a safety feature on these machines to keep it from being left too long, and causing a fire.
Apr 29, 2014 | Tefal Kitchen Appliances - Others
Projector is displaying black vertical lines. Anyway to clear this?
My vertical black lines on the same projector were temporarily resolved when I squeezed the middle of my projector. When I opened up the projector I discovered a black piece of cardboard glued over the chip board connected the projector's control buttons. It is in plain view...no digging necessary. I noticed that the cardboard was glued haphazardly and had popped up over the 3 little plastic brackets that were intended to hold it in place. I theorized that if I forced the edges of the cardboard under it's intended brackets, it would add pressure...the same pressur I had to apply with my hands from the outside. Amazingly, it worked! How long, only time will tell. Inside everything is held together with tape, glue, pieces of cardboard and a prayer. It is a piece of junk with a bright bulb. I also q tipped and alcoholed a couple of spots but I don't think that was the solution. Hope that helps!
Jan 29, 2013 | InFocus IN1100 DLP Projector
Can you bipass the ac clutch pulley??
You should be able to you will just have to figure out what length belt you will need as it will have to be shorter. If you have a flexible sewing type tape measure you can wrap it around the pulleys you intend to drive and add a couple of inches to allow adjustment.
Jan 12, 2011 | Ford Escape Cars & Trucks
Locks on video frames then is fine then skips with bars through video sound is spotty _ the tapes first 10 minutes is great and then the problem- then a recorded hockey game at the end plays fine
If this happens on one tape and you get the same video anomalies every time at the same spot the tape is bad.
If it's random and not exactly repeating you could also try cleaning the heads.
Dec 29, 2010 | Canon Sony DVM-60 Min. miniDV tape - 6Pack...
Hello! I have a Sanyo VHR 120E video recorder. The trouble is that the tape remains and it does not add up! How can you make out of it?
Tape remain counters are never accurate. For one thing VCR tapes are made by different makers and some like to give you extra. Some counters allow around 5 minutes extra at the end of the tape. Treat all times as approx, then you can't go wrong.
Nov 19, 2010 | Sanyo Televison & Video
Still get 3 rings after xclamp fix and applied arctic silver 5
Take your metal case, and drill holes big enough to fit 5m diameter x 16mm tall screws. Put them all up through the holes and add 3 steel washers to each post. then add 1 nylon washer. >>>make sure you do the penny fix or replace the thermal pads before you place your motherboard inside the case<<< Place your motherboard inside of the case ( you can use tape on the back side of the metal case to hold screws in place; may want to do that before you add washers) add 1 nylon washer then 1 steel washer to each. Take off microsoft's bolts from the heat sinks and re-apply a ssmmmallll amount of thermal paste (size of a piece of rice for the big ones). Attach everything and you will be good to go.
Penny Trick- Take 2 pennys, wrap them one way with electrical tape, then turn 90 degrees and wrap them again so no copper is showing. >>You will need 4 sets of 2 pennys<< Flip your motherboard over and peal off the white things with band-aid looking squares on top of them. Peal the band-aid looking squares off and apply your tape-wrapped pennys.
Note: If you do not have these puddy-looking things on your ram chips, Use some hot glue, not a lot though.
You may also need to "bake" your 360. When you are all said and done with applying and bolting things. Take your 360 and put everything in except the fan. Take the fan plug it in its spot, then lay it diagonally from its plug, ontop of the tall cpu heatsink. Turn your xbox on for about 15 minutes. Let it over heat good so it can reset itself flat. Turn if off and let it cool down for about 20 minutes. Put everything back together and enjoy your console as your paid for it! smile.gif
Aug 20, 2009 | Microsoft Xbox 360 Console
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Time code problem -- footage disappearing
Menu setting - the time code is simply resetting itself.  If you intend to edit your footage with NLE software this will be a problem, otherwise no issue.
Jun 08, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
frontier.com Logo
16 people viewed this question
Top frontier.com Computers & Internet Experts
David Payne
David Payne
Are you a frontier.com Computer and Internet Expert? Answer questions, earn points and help others
