Question about Husqvarna Commercial Zero Turn Mower Iz4217
Left turn pump replacement - Husqvarna Commercial Zero Turn Mower Iz4217
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
It is a pump/wheel motor or a unitized transmission.
pump/wheel motor just change the pump but always do a filter/fluid change as well.
unitized transmission replacing the pump is not something recommended because if it's bad then something else is as well
Posted on Oct 20, 2013
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
Engine cuts off when making deep left turn
may be the fuel supply system have some complaint.try to check it.also try to check the ignition system
Aug 06, 2008 | 1995 Chrysler Concorde
Hard turning left
If it has power steering better be looking at replacing the power steering pump. It takes more power to turn the wheels at a stop then when moving I have had that problem and it was the pump. Good luck O by the way it is not hard to replace the pump you can do it in about an hour all you need is a power steering pump pulley puller. You can rent one at any auto zone store.
May 15, 2014 | 2004 GMC Sierra 1500 Crew Cab
Cant turn my 2003 toyota 4 runner to left or right
with the wheels on the ground, if you pull really hard on the steering wheel will the wheels turn?
Since you already replaced the pump the only thing left is the rack and pinion.
Apr 02, 2013 | 2003 Toyota 4Runner
The pulley on my power steering pump stops turning when i turn my my wheel left or right
I'm getting the same issues except its only when my wheel is turned all the way to the right or left. I just replaced the power steering pump and tightened it, yet the screeching still continues.
Jan 09, 2012 | 2004 Chevrolet TrailBlazer
Engine stalls when turning left hand corners.
turn left, sputter, sputter, pop! sputter, sputter..............vvveeerrrooommm !? WTF? Crazy 91 Honda CRX just became a death car tryin to get through an intersection. Checked all my wires and ended up in the gas tank tryin to put the fuel pump back together. POS pump is in the left side of the tank!? So if you got a few miles on it the fuel pump screen can fall off. Turn left and the last 1/8th of a tank goes to the right leaving a 3/4 ton chevy in your girlfrends lap...well almost. I still got the CRX, the girl got droped off at the car wash cuz she smelled like poo.
Jun 06, 2010 | 1985 Honda Civic
On my oldsmobile aurora, I have a problem turning left. It's as if my power steering pump doesn't work when I try to turn left. I replaced the pump and the left cv axle because it was bad, but still having...
More than likely your rack and pinion has gone bad. If the pump was bad it wouldn't work to either side. But the rack and pinion can go bad on just one side
Nov 15, 2009 | 1997 Oldsmobile Aurora
Front whine when turning left and at whine when starting driving. Power steering and transmission fluid good level.Steering is good. Transmission shifts good. Some fluid on carport located left front of...
Whine usually occurs on tight turns maximising pump output and/or pump may be worn and needs replacement. Leakage can be from pump reservor,connection, or power rack and pinion steering assy. Spray off any area with a sign of fluid with a brake clean or carb. cleaner and look for signs of leakage.
Oct 08, 2009 | 2005 Buick LaCrosse
Husqvarna Commercial Zero Turn Mower Iz4217 Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
