Question about Sharp Imagistics 1500 Printer/copier/fax Machine Usb/parallel
Replaced the drum. still says offline replace drum
Shows status offline wont print
Replace with a new drum, clear your print que. reset network and printer
Aug 20, 2015 | Canon Genuine Oce Imagistics Fx3000...
Will not print. it says printer is offline
Have you tested the Cable ( maybe test with a replacement)
under your devices and printers is the checkbox on use offline, printer - see whats printing - printer - uncheck use offline
Apr 05, 2014 | HP Officejet Pro 8600
Printer still say need new drum even after being replaced
You need to reset the drum count. take the printer offline by pressing the online button. next scroll down on the menu button til you get to Maint. Menu. Next press Item+ button 2 times. LCD should say Drum count reset. next press select button.this will save the option. next press online button
to put the printer back online. you should be ok to print
Good Luck
Feb 23, 2011 | OKI B4350 Laser Printer
Ibm bladeCenter -S storage one hdd offline .how to forcely online
It probably is "offline" because it is "dead", and thus cannot go "online".
Replace the disk-drive, and the replacement should go "online", automatically.
Jan 23, 2011 | IBM Bladecenter H 88524XU Hard Drive Array
Okidata b 4600 keeps saying change drum
You will need to replace the printer's drum cartridge. Just google oki b4600 drum to get hold of one. In the package will be a reset routine to follow when you do this.
Jul 06, 2009 | OKI B4600n Printer
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Sharp Imagistics 1500 Printer/copier/fax Machine Usb/parallel Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
