My msi pc doesnt detect its own keyboard or any other usp keybords. It detects other devices but not keyboards. The keyboards work on ther pcs but not the msi
  • 3 Answers
Try to go in bios setting
Posted on Oct 19, 2013
  • 11 Answers
SOURCE: Keyboard not detected
There are some steps to figure out what is causing this.
If you have a desktop:
1. Replace with another keyboard that you know works.
If it boots, than it is the keyboard that was bad
2. If it doesn't - try getting into bios. There is a secion for
keyboard and make sure it is enabled.
3. If it is enabled, than it would be the port for the keyboard that
is the problem. You can take the computer apart an replace
it, or take it to someone who can fix.
If you have a laptop:
1. Add a keyboard to the computer.
2. If it boots, than it is the keyboard on the laptop. This could
mean it is not connected, you have the wrong drivers, or
try getting into BIOS like #2 above.
3. If the keyboard is enabled in the BIOS, reinstall drivers
first. If this doesn't work than there is something wrong with
keyboard (follow #3 above).
(BIOS - when computer boots up, look closely. There is a button you must press to get into setup mode (BIOS). I press F2 on my computer to enter BIOS. Some computers are different).
Posted on Nov 10, 2007
SOURCE: Dell bluetooth keyboard/mouse bundle
My wireless mouse and keyboard is not working right.
Posted on Oct 06, 2008
  • 38 Answers
SOURCE: keyboard doesn't work
If you have droped any kind of liquid on the keyboard get it replaced
Posted on Aug 03, 2009
  • 17 Answers
SOURCE: the computer does not detect acer sk-9610 keyboard
use driver easy a free tool to download drivers http://www.drivereasy.com/ just plug in the keyboard and scan for drivers using driver easy and it will download the drivers for you :)
Posted on Jun 16, 2010
Ezrahite
  • 2632 Answers
SOURCE: I just purchased a Gigaware
Welcome to Fixya. Can you please make sure that the usb bluetooth device / receiver is connected to the computer. make sure that the on/off switch of the mouse and keyboard is on. The keyboard and mouse switch is on the bottom. Press it for 15 seconds. The receiver will flashes when connected.You can also refer to the manual below for more info.
Gigaware Wireless Mouse and Keyboard Manual
Thanks for using Fixya.
Posted on Aug 21, 2011
Msi keyboard not working
When you plugin the keyboard do you get indication that it is detected? If so you may need to go to your device manager and disable the laptop keyboard to enable the MSI one.
Oct 16, 2013 | Computers & Internet
Cant typ from keybord
Dear user if you cant type from keyboard then goto your control pannel and select hardware setting then driver and printer after that please click on mice and detect your problem. now you can type from keyboard.........try it and comment me
Jul 06, 2011 | Computers & Internet
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Wireless mouse works not keyboard
check the batteries in the keyboard, if they are working then goto control pannel and goto install new hardware and try installing your keyboard driver from there. if it is nit getting detected then goto device manager and try to check from ther if you can detect your keyboard from ther.
Aug 08, 2009 | Computers & Internet
Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Nov 11, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Keyboard locked
if you have usb keyboard then remove ur keyboard and restart windows. when it goes on then insert the connector. it will detect that one and may be it start working. or go in properties of computer--->device manager--->usb composite device and uninstall it from the top bar and then install it. it will detect all usb devices including keyboard.
Jun 22, 2008 | E-Machines eMachines Desktop PC
Keyboard
Hi
Go to cmos by pressing del or F2 change sitting in advance sitting change usb work in dos or usb in all mode...
Thanks
Jun 17, 2008 | MSI MS-1012 Notebook
Keyboard detection problem
if the kb works on another system then the ribbion is ok, right?, the port on the motherboard is broken, which is almost certainly integrated(soldered to the board with no wires in between) which means to replace just the port you need to get a desoldering tool and cloth and a soldering iron(do not use a gun, they are not as acurate when working with this small of a space) and of course some solder, not to mention the replacement part or a more seriously broken laptop with the same part that you can take apart, seems like a lot of work to resurect a laptop, i would suggest a new board, new laptop or get a usb kb, maybe one of those rollup ones they sell on thinkgeek.com so you can retain some of the protablity, then again since the onboard kb is not functional it just sorta becomes deskspace for an external one. the fastest cheapest fix would be an external keyboard, next time i would recomend knowing what you are doing a little better before working on a valueable system or any that you cannot afford to loose, I see people break the ribbion cables and connectors all the time when working on laptops, its usualy because they dont know how to open the clips on the connectors, anyways try to be more careful next time
Jul 09, 2007 | Toshiba (225EXTR5)
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
