Its called an NTC it measures the temperature of the drying air going into to the drum
Thanks for that, any idea where i can buy a new plug for the ntc as both cables broke free?
Hoover did a modified ntc and cable as they had quite a few them break, ive not seen one for a while but if i remember correctly its but very fiddly to take the top of the plug off and refit the wires, have you got the model numberk
SOURCE: water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
SOURCE: metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
SOURCE: Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
SOURCE: Washing Machine Door seal replacement
Hi, I'm not familiar with your particular model, but there is most likely a very similar type of clamp holding the back end of the seal to the static part of the drum. It is most unlikely that you will need to take off the front cover as on most machines only the back and top are removable. You might need to unfold the rubber to get to see the wire which is holding it on. If it is the type of clamp with a screw-tightening device, it might be rusted up and a new one might be called for.
If the old seal is damaged there is nothing to be lost by cutting away some of it with scissors so you can see better what you are doing.
When you get to the stage of putting the new seal on, try lubricating it with a bit of washing up liquid or soap to allow it to slip properly onto the casing and rum, and try to avoid tightening up with a twist in it - the soap should help. Remember to put the new one on in the reverse order to the way you got the old one off.
Hope this helps you a bit more. D
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
