Question about Sewing Machines
My machine is jammed up. It started with a thread jam in the bobbin, but I think I got all the thread out and it still won't move.
    Champion:
  • 208 Answers
Quite possibly you have a minute piece of thread still stuck in the raceway
Posted on Oct 19, 2013
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Posted on Aug 08, 2008
  • 8 Answers
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
Posted on Nov 28, 2009
Tally Girl
  • 1129 Answers
SOURCE: Elna 2007 sewing machine breaking upper thread in
Is your top thread tension on 1? this sounds way too loose, should be 4 or 5.
This is a horizontal top loading bobbin machine isn't it like the Janomes?
Do you have a manual for it? It sounds to me like the top thread is too loose and as it is pulled down and around the rotary hook there is no tension on it to pull it back up through the fabric and form a stitch which is then causing it to jam. Then once youve gots bits of thread in there, its just jamming and jamming. Cleaning out the bobbin holder as you described is good, you may need to do it again and ensure all bits of thread are out of it.
I think you need to revist all the threading up and ensure that the top thread is under tension, try number 5. Also check that bobbin is correctly wound nice and smoothly, then loaded into the bobbin holder correctly so that the thread is coming off the bobbin spool in the right direction, ie thread needs to come off the bobbin, then reverse direction in a "v" shape, usually in the direction of the back of the free arm. And that the thread has been clicked into the tension spring fully, put the thread into the slot of the tension device and press down on it with your finger tip until you hear it click into tension.
Also double check the take up lever, if the thread has slipped out of this, it will jam up for sure.
If you don't have any manual for this then try www.sewusa.com, there is good troubleshooting tips and threading diagrams for lots of makes and models.
Hope this helps you, persever, its most likely threading/tension issues and can be overcome with the right settings.
Posted on Aug 25, 2011
SOURCE: My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Posted on Jun 08, 2012
The bobbin jams up after three or four strokes of the needle
You possibly have the incorrect bobbin type, or there might be scratches on the bobbin, or it is threaded incorrectly in the bobbin case. Hope this helps.
Mar 13, 2014 | Brother XR9000 Sewing Machine
Juki ddl 8300n
The part that holds the bobbin case down must have enough room for thread to move across the top of the bobbin case without getting jammed. Turn the hand wheel while you monitor the movement of the thread. If it gets jammed you will have to adjust the holder by loosening the bottom screw and move just a small amount. Also check your bobbin to make sure it is the right size. If it is too high it will jam the thread.
Mar 24, 2017 | Sewing Machines
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
Bobbin won't move
Check for thread caught under silver guide, may have got jammed in there.
Aug 16, 2012 | Singer Quantum XL-6000 Computerized Sewing...
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Elna 2007 sewing machine breaking upper thread in bobbin unit. It will be going along fine then the thread will snap. thread tension on 1. zigzag stitch. Thread passing through upper machine OK, but...
Aug 15, 2011 | Elna 2007 Mechanical Sewing Machine
When I turn the knob to move the needle to catch the bobbin thread, it hits something underneath and won't keep going down. The same thing happens when I turn the knob in either direction. It's...
Have you removed the bobbin case to clean it? If so, it probably needs to be reseated. Remove the bobbin. Take out the case and reinsert it. If you can't get the bobbin out easily, there is probably thread clotted up somewhere under the feed dogs. I usually gently rock the handwheel back and forth as I brush the bobbin case area to begin dislodging the "clot." It also helps to remove the throat plate so you have a better view of the mechanics under the feed dogs. You'd be surprised at all the goop that can be caught but you can't see. If you do find a thread clot, use a machine brush and tweezer to gently remove each thread bit. I really hope this helps you. If it does, please come back to Fixya and rate my advice. Thanks!
Aug 01, 2011 | Brother CS6000i Computerized Sewing...
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
Bobbin thread jam
You can remove the thread jam by moving the hand wheel back and forth. Remove the bobbin case and bobbin.Unthread and remove the needle.Rock the handwheel back and forth. Don't be rough but you will need to exert a little pressure to get this thread to come out. What you are doing is cutting the thread which is locked inside the hook race.
sewman7
Sep 03, 2008 | PfaFF Creative 7570
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
