Question about Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose
Right side lights are not working in a VWjetta 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 162 Answers
Check all fuses in fuse box's
Posted on Oct 20, 2013
My 2009 impala blows low beam right side every couple week
When working is light as bright as the driver side low beam ? Dim ? What's the headlight socket look like ? Burnt ? high resistance ,drawing to much current . Do you know how to do current draw testing ., Voltage drop testing ? Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Feb 21, 2017 | 2009 Chevrolet Impala
How to fix a 2009 Honda accord brake light on the drivers side. I replaced the bulb on both side but still the brake light doesn't work on the drivers side.
Go to www.bbbind.com for a wiring diagram of the brake light circuit , get a DVOM - digital volt ohm meter an trace out the circuit . You know the right side works so the brake light switch is good . Take your volt meter an check to see which part of the circuit is bad . At the brake light bulb socket test for voltage on the power side , if battery voltage is there,then check ground side . I forgot you need to have some one press on the brake pedal while testing . You could have a bad ground or an open on the power side of the circuit , you need to find the wiring harness that goes to the back of the car , check connectors ,wiring etc... There is more to electrical trouble shooting then just replacing parts . Watch this video on voltage drop testing . Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Oct 28, 2015 | 2009 Honda Accord
Trailer hitch
check your fuses some newer vehicles have separate fuses for trailer lights this could be the problem
Jul 23, 2014 | 2009 Chevrolet Traverse
2009 dodge grand caravan error message on dash board no bus or no bu5
the info bus is down try unpluggin the crank sensor on the right side of the transmission see if no bus goes away al see computer cause this issue
Nov 20, 2013 | 2009 Dodge Grand Caravan
Car crash shorted tail lights how do i fiox it?
OOPs! First thing to do is make sure all the wiring on the headlamp/side lamp units are not damaged or cut if so repair also check fuses they will be marked on fuse box lid...Good-luck.
Dec 30, 2012 | 2009 Toyota Corolla
Starter location 2004 vwjetta 2.0
back of engine ,need it up in the air to get it off and a suppot bracket out of the way as well if i remember rightly ,dirty job as well not for a weekend mechanic unless really keen
Dec 25, 2012 | Cars & Trucks
2009 Impreza 5-door left tail light and turn signal don't work .
first of all check and confirm whether in the fuse box separates the left from right side and see for blown fuse. or check for any disconnection on the rear light
Aug 10, 2012 | 2009 Subaru Impreza 2.5i
I need to know which fuse number for lights
Turn Signal (Right) white/tan (F), white/yellow (R) + TIPM, green 16 pin plug, pin 3; green 26 pin plug, pin 4
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger side fender.
Headlight white/brown -1.2K ohms [2009 = same] headlight switch or instrument cluster, gray 26 pin plug, pin 3
AutoLights same as headlight
Reverse Light white/lt. green + [2009 = same] passenger kick, harness to rear
Left Front Door Trigger purple - [2009 = VIOLET] driver kick or instrument cluster, white plug, pin 3
Right Front Door Trigger purple/white - [2009 = VIOLET/white] pass kick or instrument cluster, white plg, pin 16
Jun 25, 2011 | 2009 Dodge Challenger
I have replaced the stock tail light assembly with
i dont know alot about this but my best gess is you have a bad ground check and make sure you have a good solid connection. hope this helps you.
Jan 03, 2010 | 2008 Triumph Triumph Bonneville
Right rear brake light and blinker not working
Daniel,
Should still be under warranty. If you have determined it is not a burned out bulb, let the dealer trouble shoot.
Some other things to check, from a wiring standpoint, does the right side emergency flasher work? Does the right side backup light work?
If these do not, I'd look for a connector to the right side of the rear that came loose. Haven't spent that much time under my 2009 (same model style), but I'd suspect on a jeep that physically following the wires to a connector would not be hard. Also could be a ground issue to the right side lamp housing.
If those are working, morelikely a broken wire.
Jul 30, 2009 | 1997 Jeep Wrangler
Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose Logo
134 people viewed this question
Top MK1 Originals Vehicle Parts & Accessories Experts
mekanik84
Mark Cunningham
Mark Cunningham
Level 1 Expert
Rigger
Are you a MK1 Originals Vehicle Part and Accessory Expert? Answer questions, earn points and help others
