Question about Briggs & Stratton Garden
16.5 hp engine locked up. Is it repairable? - Briggs & Stratton Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Yes it can be...
is it locked up from lack of oil... then no, you dont wanna mess with it.
is it locked up because the cylinder is full of fuel or oil... pull the spark plug and check.
is it locked up because the cylinder is gummed up from gelled fuel ( i've seen it more than once ) yes it's worth some effort
Posted on Oct 20, 2013
How do I replace condenser on 16hp brigs
a condenser on a brigs 16 ,,,, well heres my dilemma on answering this , as accord to my books , briggs didn't have an engine that size that had points the biggest they had was a 12 hp (and its a monster too as I have one on a mortar mixer) it's got way more torque than a modern hp engine that same rating ,I could never replace it , as accord to my books when they did decide to make that size and above all the way to 21 hp the times progressed far enough that electronic ign had arrived , and they don't have condensers , im thinking you have a large 12 hp (like mine) the points and condenser is located under the flywheel , your need a flywheel puller to get that off (losen lock nut 1st) and carefull heat helps the points and condenser is in center just next to shaft , under a little tin cover one 5/16 screw holds it down (I suggest replacing both )
May 15, 2015 | Garden
Plastic chain gear broken; need to replace. where can I get the part?
Check with a local small engine repair shop-one that works on chain saws. They should be able to order you one.
Aug 29, 2013 | Worx (16") 3.5 HP Electric Chain Saw -...
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Toyota Corolla Cars & Trucks
The safty lock for blade will not reless how do you reless
Pull the side cover completely off, there should be a band brake inside that is probably full of dirt and oil. Engine de-greaser and compressed air help. Work the safety handle back and for to make sure it's free once you have cleaned it.
Feb 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chain keeps freezing up on me and its brand new. how do I fix tha t on my husqvana 16 inch
Turn the chain brake off, then remove the bar and chain. Clean the side of the engine where the bar fits to, start the engine and observe whether the small oil port on the engine oozes out oil. If nothing and the oil tank is filled, put the saw back together and take it back to the seller for warranty repair of the oil pumping system or a fresh saw in exchange. Hope this helps!
Dec 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
16 hp briggs vangard blows clouds of smoke under pressure
Normally the smoke is cause by one or two problems.
1...too much oil in the crankcase, lower oil to correct level and smoke will stop.
2. broken rings,bad valves inside of the engine, major overhaul or replace the engine with a new one is the only repair for this problem.
Please rate me
Nov 09, 2010 | Garden
Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
16 HP briggs and stratton poulan severe flooding
The carb is not closing down properly. You will need to either rebuild the carb or just replace it. Basically the float is staying open after you shut the machine down. Please rate
Jun 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Cyan is offset about 3/16"
check the locking tabs on the cartridge, sounds like they are not locking down the cartridge.
Jul 31, 2009 | HP LaserJet 3600n Printer
Garden Logo
57 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
