Question about Sanyo SCP-3100 Cellular Phone
Manual Programming Instructions
Changes providers from Sprint to Cricket, and phone was programmed through cricket. The phone got cut off. Now that it's back on. Need manual programming instructions in order to reprogram the phone. Please help. Cexi
  • Anonymous Dec 26, 2007
    i have gotten to the part where it says
    Enter in the following
    a) #
    b) # (again)
    c) 6-digit Activation Lock Code
    d) #
    e) MENU-OK
    and i dont know what to do!
  • 21 Answers
Cricket should have that information. Just call in. Hope that helps :)
Posted on Nov 14, 2007
SOURCE:
How can a person flash a boost mobile to cricket nd full instructions
Don't think you can, boost mobile uses sprint CDMA network. And cricket uses at&t gsm network, they aren't compatible. I think cricket used to be CDMA, then at&t took over.
Feb 19, 2015 | Cell Phones
Tip
Manual Programming Code
To hand program the Motorola V3m Razr make sure you are at the main screen and type the following fairly quickly.
#073887*
then a new screen will come up asking for a security code.
Most of the time it will be 000000 but if it is not you will have to get it from your provider(Alltel, Verizon, Sprint, Cricket....etc..)
Then from there choose User Activation and then you will have 4 settings
MDN.....
MIN......
SID......
IMSI......
Your MDN is always going to be your current phone number.
Your MIN will sometimes be your phone number but not always. So while you are talking to your Wireless rep be sure to ask them for your MIN and SID
Your SID will be provided by your Wireless Rep.
Do not modify your IMSI
After you have entered these settings just press Done and then the End Call button to return to the main screen. Your phone will not powercycle and you can resume using the auto updated by dialing *2 for sprint or *228 for most other providers.
on Jan 27, 2009 | Motorola Mobility RAZR V3m Cellular Phone
I want to flash a metropcs phone to cricket
Flash or Flashing--Technically, flashing refers to the overwriting or re-writing of the phone's firmware. There are many phones which can be flashed to cricket with all features working. On most CDMA phones, programming the phone can be done "over the air" by dialing a special code, usually *228 or some variation. Colloquially speaking, flashing can also loosely mean making a phone from one carrier work on another carrier. The easy way to tell the difference is that if your phone does NOT take a SIM card, then it is probably CDMA.
To flash a phone to cricket you will be overwriting th phones firmware. The firmware is software in the phone that doesn't change when you turn it off, and it cannot be deleted unless it is overwritten, hence flashed. It requires specific files called prl files.PRL or PRL File--Short for Preferred Roaming List--A small text file containing instructions for how a phone connects to a specific network's radio towers It is usually loaded by connecting the phone to a computer to overwrite its data. There are a few tools used such as a pst PST--Short for Phone Service Tool or Tools--Special software used by phone manufacturers to program their phones. And also a monster file - -"Monster File"/"Monster Pack", ROM, or "Kitchen"--System software that is needed to flash a phone.
In almost all case you will need to access the phones service programming menu- - -Service Programming Menu--A special menu typically hidden from the primary User Interface that allows for "deep programming" of a phone.You will also need access to msl and spc codes specific to the device you are flashing.MSL/SPC--Special six-digit codes needed to access service programming features on the phone. Access to the service programming menu can be disabled in a phone's firmware.
Depending on your phone, it may require extra steps to unlock or get WAP and MMS working. That is why you need the msl/spc codes to allow deep programming to unlock these features. Not all phones will be capable to access wap or send and receive mms.
Ringtones generally have to be prepaid using a flex bucket. It is best to download ringtones before you flash your phone to cricket since they have a limited selection of ringtones and wallpapers.There are cases were flashed phones will not be able to download ringtones directly from cricket.
The details outlined above will not only work with cricket but you can also flash phones to metro pcs using the information provided above. It is best to do all your research before purchasing your phone to ensure that the cell phone you are interested in can be flashed to cricket or metro PCs
Feb 21, 2012 | Motorola SLVR Cell Phones
How to flash samsung rant from sprint to cricket
For the flash you will want to take your device to a cricket indirect dealer. Direct Cricket stores will not flash your phone.
Cost varies depending on what store you take it to.
Cricket also cannot guarantee that all features will work and if something doesnt work they will tell you tough luck. They dont provide support for non cricket devices.
Aug 20, 2009 | Lands Phones
Hi people. i have the SAMSUNG sprint phone 'RANT'. and i have flashed it to cricket. and i really really want ringtones. i cant recive or send picture messages. i even tried bluetooth and nothing works. i...
actually, it is not possible to download ringtones to a Rant from Myxer. You have to use a phone uploader with ringtones from your computer and send yourself a "jump code". Unfortunately, Cricket does not offer this option.
Jun 15, 2009 | LG enV VX9900 Cellular Phone
How do i convert alltel razor to cricket wireless
I also have a razor, and my phone company is cricket. When some one wants to change service to another company, sometimes the company they are switching to can "flash" the phone with the companys particular software, thus making it function with the new service. However, Im not sure if cricket has the capabilites to do this. Personally, ive been using cricket for close to five years, and I can honestly say that in means of customer service and quality, cricket is not the way to go. Im personally planning on switching to Verizon or Sprint soon and just buying a new phone altogether due to the lack of quality the phone and the service from cricket provides. Ive gone through several phones from cricket, and they were all fairly shabby. As a rule, DONT buy a Kyocera phone from cricket, they are cheap and not meant to last.
Apr 15, 2009 | Motorola Mobility RAZR V3
Manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Feb 03, 2009 | LG enV VX9900 Cellular Phone
Sanyo SCP-3100 Cellular Phone Logo
265 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Steve Allison
Steve Allison
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
