Question about Precor 9.21 Treadmill
Control panel buttons not working - Precor 9.21 Treadmill
    Top Expert:
  • Precor Master
  • 12,223 Answers
If your sistem ( has batteries, replace by new ones, but clean the contacts batteries from dirty, oxide, etc use contacts cleaner and tight the spring with pliers)>
2) tight the ribbon cable inside the display board.
3) tight and clean the upper and lower connector from display.
4) adjust the REED swtich. see the diagram attached.
God bless youcontrol panel buttons not working - b1b5c2bb-18f3-46fa-9036-ad938e150119.gif
Posted on Oct 19, 2013
Start/pause button is not working on my LG washing machine. All other buttons are working fine?
Problem maybe that the START/PAUSE button has broken loose from the control panel. All the buttons are attached to control panel and "hinged" so when you press the button, the button presses a small button switch on the display control. You may have to order
the Control Panel.. Disassembly is required to inspect.
It would be least likely that the Display PCB is bad..
Aug 19, 2014 | LG WM1814CW Front Load Washer
My start button doesn't work, very loose, appears to be off track to engage
Had same problem but solution was different. Start button looked slightly misaligned and wouldn't always work. Followed instructions to pull off front control panel, removed LED display panel and the plastic tab that the start button was attached to had broken off from the panel. Used a good epoxy to glue the edges back together and it works like new. Also broke two tabs that hold the LED panel inside the front plate due to the plastic becoming brittle. Again, epoxy is your friend. Works like new. d04211d8-3b3d-44fc-bc8c-6da6cd6ecf7e.jpg
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
My Panasonic PT-LB20NTU Multimedia Projector i locked my controls on the menu button and now it wont poer on and none of the buttons work
Use the remote control and press the MENU button and select the OPTION with the UP and DOWN arrow buttons. Press ENTER button and then press UP and DOWN arrow button to select CONTROL PANEL use LEFT and RIGHT arrow button to VALID the control panel buttons
If you have a loss of the remote control while the control panel is invalidated.
Press and hold the MENU button for 2 seconds with pressing the ENTER button to enter the MENU and VALID the control panel.
Nov 19, 2010 | Panasonic PT-LB20NTU Multimedia Projector
Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Jul 04, 2009 | Dishwashers
Precor 9.21 Treadmill Logo
69 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
