Remove rear wheel bearing BMW 325i - Computers & Internet
    Master:
  • 492 Answers
Try searching on YouTube for a video you can watch.
Posted on Oct 18, 2013
Where is the speed sensor in bmw e30 325i?
The vss or vehicle speed sensor for E30 series BMWs are located in the differential.
/uploads/images/speed-sensor-in-bmw-e30-325i-34720300-5-1.jpg
Nov 03, 2014 | Vemo 1992 - 1995 BMW 325i Vehicle Speed...
BMW 325i noisy fan bearing Can I replace it.
yes easy you remove the fan and change the whole unit its not repairable
Nov 25, 2010 | 2006 BMW 3 Series
How to replace rear wheel bearing on 1994 bmw 325i
3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
  • Detach wheel bearing inner race with special tool (33 4 400) through groove in bearing inner race.
  • According to outside diameter of bearing inner race, use special tool 33 4 401 with: 33 4 405 for dia. 45-51 mm, 33 4 406 for dia. 50-55 mm and 33 4 407 for dia. 55-61 mm in groove. See Fig. 35.
  • Tension special tool 33 4 401 with wrenches 33 4 403 and 33 4 404 until it can still just be turned in groove. See Fig. 36 .
  • Screw in special tool 33 4 402. Detach inner bearing race.
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
Nov 12, 2010 | BMW 325 Cars & Trucks
My 94 bmw 325I transmission is slipping and not shifting properly. How can I check the fluid level and add fluid if needed? Thanks Vince M
on the drivers side of the transmission under the car is a plug similar to a rear end in the older rear wheel drive cars bmw has
a lifetime tranny fluid setup so take out the plug and fluid should drip out its right behind the shifter cable if it dosent drip out youll need a pump to put it in you can get these at advance auto
May 12, 2010 | 1994 BMW 3 Series
Can I tow a 2003 BMW 325i behind a motor home without a trailer
depending on the distance if it is a rear wheel drive car some remove the drive shaft as a precaution to prevent damage to automatic transmissions
Jul 03, 2009 | 1996 BMW 318
Need to see a diagram of how to change rear wheel bearing on my 320 touring 1996
BMW uses CV shafts for the rear drive axle, the wheel bearing there is a pressed in factory sealed bearing and not removable other than using a press to remove it, to press it you will need to remove the lower control arm.
May 22, 2009 | 1999 BMW 323 Series
How to remove fuel pump on 1989 325i bmw
remove rear seat and look for plastic big round cap
May 21, 2009 | 1989 BMW 3 Series
How to replace rear shocks on 2003 bmw 325i
You have to take the trunk liners off of both sides. There will be 3 13mm nuts on each side for the shocks, and under the car is a 16 or 17mm bolt that has to be removed. I hope this helps.
Mar 31, 2009 | 2001 BMW 325
Noise in rear left tire BMW 325i 1988
I had the same thing happen, it was the wheel bearing. It's still costly, it has to be pressed in and old one out.
Jan 04, 2009 | 2001 BMW 325
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
