Question about Kenmore Dishwashers
Kenmore 665.13112K701 -- I can push the buttons to start a normal wash cycle and lock the controls. I hear it fill the bottom with water for about 10 seconds or so, and then instead of the normal noises I would expect to hear, all the lights on the control panel went out simultaneously and the cycle stops, leaving water in the bottom. I tried starting the cycle again, and it gets to the same point and fails. It almost acts like the power to the control board drops out or something, since there are no blink codes and the child lock disengages. Where should I look to troubleshoot this?
  • 1 more comment
  • Taliesin
    Taliesin Oct 20, 2013
    As an update, I no longer hear water coming in at all, and it doesn't fill. If I run the diagnostic on it, it makes it all the way through the 55 seconds of filling with no water present, then dies as soon as the wash pump is engaged in the next phase. So now what?
  • Taliesin
    Taliesin Nov 09, 2013
    Solved my own problem -- it was two bad capacitors on the controller board. 3 hours and 1$ later, and I'm back in business!
  • Taliesin
    Bad 5V supply caps on the contoller board were causing the microcontroller to brown-out whenever it had to turn on one of the triacs. Replaced the 2 capacitors, and now it's working.
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Red blinking light over normal wash
I had the same problem... the lock on light was blinking continuously. The solution required disassembling the door to get to the control panel electronic board. You'll notice a flat transparent cable coming out of one end, twisting under the board and going into the door panel. In the middle of the door, there's a number of wires taped together that curled over the flat cable. Look for any black tape residue on the flat cable, which seemed to be causing a short circuit and confusing the electronics. After carefully removing the tape residue from the flat cable, the problem went away.
Hope this helps :)
Posted on Apr 03, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
Hello & Welcome to FixYa
This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Kenmore Dishwashers
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Dec 29, 2007 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
