Question about Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side the vacume the condenser light keep on flashing after 12 hrs or so but the condenser is clean it could be my both door are not flushed together .Fridge side door is little out may be that is the reason.Could some one help me . Thank you
  • 45 Answers
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Posted on Oct 23, 2013
4 Suggested Answers
  • 26 Answers
SOURCE: sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Posted on Oct 24, 2008
Chadha Saab
  • 142 Answers
SOURCE: vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
Posted on May 30, 2009
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
Is it possible to clean the condenser with low velocity air compresser . My sub zero 690 side by side fridge flashing VACUME CONDENSER SERVICE.
Yes but this will create a dusting nightmare for the rest of the house. By just cleaning the condenser is not enough for the computer has no knowledge of said act. You must rest the computer after cleaning, your model has a picture of a bell on the panel of the control. Push and hold that bell for 10 seconds, you should hear a beep and the service light will disappear. If this returns, this means either the condenser is dirty or the computer has detected that it takes too long to reach your desired temp. But reset first, less work and see what happens.
Good Luck
Nov 02, 2013 | Sub-Zero 690 Side by Side Refrigerator
It starts flashing VACUME CONDENSER after 24 hrs on my sub zero 690 side by side fridge .I cleaned the condenser but some one suggested I can wash with hot water spray bottle (I did not tried).If there is...
"Vacuum Condenser" light on this refrigerator will appear if you have any kind of issues - some of their models would have "Service" light instead of Vacuum Condenser. As My expirience shows Most likely Your Fresh food section is low on refrigerant - Evaporator might leak freon - so what we would have in this case - compressor runs for longer time then suppose to - as a result "Vacuum Condenser" or (some models) "Service" appears. Another sigh of low freon pressure people would notice ice build up on the back wall of the refrigerator section on the left side on the middle. I post video on my YouTube chanel, so u can check how to fix it properly.
Oct 27, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side refrigerator . Vacume the condenser light keep on showing after 10 or 12 hrs. Is it possible if both side holding the temprature then it could be door seal?Could some one help me...
That light comes on when the unit is running more than normal to maintain temperature. Have you vacuumed the condenser coil at the top right of the unit? It could be that simple. There is also a fan up top to move air thru the condenser that may be stalling out and not circulating air. The most expensive cause would be a sealed system issue such as a refrigerant leak. With a replacement cost somewhere around $10,000 you may just be better of locating your local authorized service center.
Oct 17, 2013 | Sub-Zero 690 Side by Side Refrigerator
Another question by me
Most likely that light is caused by a refrigerant leak somewhere in the fridge system. Most likely the fridge evaporator, but you would need a leak detector to confirm this. It could also be that the fan to cool the compressors is not running all the time, or that the compressor itself is weak. Do you have any error codes? Is there a ball of ice forming on the back wall of the fridge section on the left side towards about halfway down from the top? what is build date on the serial tag, located on the frame of the fridge inside the freezer door at the top. Good luck, hope this helps.
Oct 16, 2013 | Cell Phones
Sub zero 690 side by side ,I have clean the condenser but vacume condenser keep on flashing .Turn the fridge off from the circut then on but same words are flasing after 12 hrs or so.Fridge temprature is...
MOST LIKELY FRIDGE SECTION IS LOW ON FREON! "VACUUM CONDENSER" WILL COME ON IF COMPRESSOR RUNS MORE THAN IT SHOULD BE. COMMON THING IS LEAKING EVAPORATOR COILS IN FRESH FOOD SECTION. CHECK MY VIDEO, I HOPE IT HELPS.
Oct 13, 2013 | Sub-Zero 690 Side by Side Refrigerator
After cleaning the condenser message comes after 12 hours or so vacume the condenser
Sep 16, 2013 | Sub-Zero 690 Side by Side Refrigerator
Cleaned the condenser on model 690 sub zero side by side after 12 hour or so it says vacume the condenser......thanks
Is this still an issue as this post is a month old? Was the computer cleared after cleaning? If not, hold the (bell) button for 10 seconds and you should heard a beep. This will clear the computer (the fault from the screen). If it returns you may have a cooling issue only the computer noticed, you made need a service tech to look at this. But only if this continues.
I hope this helps.
Sub-Zero 690 Side by Side Refrigerator Logo
90 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
