Question about Grohe Home
KWC soap dispenser leaks at the counter level
  • 101 Answers
SOURCE: soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Posted on Dec 14, 2008
  • 68 Answers
SOURCE: Soap Dispenser leaks soap onto counter
maby minor crack between the the treds on the bottle that screws in to the pump or a crack in the bottom of the pump and you may not see it because the pressure of the pump isint in the bottle when you un screw it tot look at it
Posted on Jun 27, 2009
SOURCE: kwc kitchen soap dispenser wont work
Replacing this is not a very good option since KWC dispensers are expensive. I fixed 2 of these that had chunks of copper corrosion inside the thin spout, blocking the flow of soap. To fix it, pull off the metal head, flush warm water into the hole at the base and end of the spout, and run a thin wire (bread tie, etc) through it. The debris can be flushed from the end of the spout back into the base, since the end has a very small hole and the base has a much larger hole. This is only a 10 minute job.
Posted on Jul 06, 2009
  • 115 Answers
SOURCE: Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Posted on Jul 26, 2009
  • 25 Answers
SOURCE: Dispenser working but had new granite counter installed and it is now thicker. Need a longer shaft to screw soap dispenser on u der sink
Take both pieces to hardware store they may have the top only. If not, they sell soap pumps made for granite counters.
Posted on May 27, 2012
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
May 09, 2012 | Moen Soap & Lotion Dispenser 3910S
Purchased soap desp. model #RP47280SS with no directions. Left white ring with dispenser on counter and used rubber washer and plastic nut on bottom. I can't get the dispenser very tight to the...
bobj50-
The white washer goes underneath the counter (with the nut) and the rubber gasket on top of the counter under the dispenser head. You may find it easier to tighten the assembly with this configuration. As for filling the bottle, unfortunately it must be unscrewed from under the counter in order to refill it.
Hope this helps.
Regards,
DIYpro
May 17, 2011 | Delta & Soap Dispenser
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
Re: soap dispenser of my K-R10430 Kohler 4-hole faucet. The small spout has started coming out of the body of the dispenser when dispensing detergent. Installation and homeowners guide don't show whether...
I'm not sure if it can be repaired or not, but lowes carries the same dispenser that came with faucet. To replace unscrew bottle from under counter now you remove plastic nut that holds the body to counter and install new one.
Sep 28, 2009 | Plumbing
May 17, 2009 | Grohe Satin Nickel Soap Dispenser...
Kwc kitchen soap dispenser wont work
Sorry but you need new one, the cheapest I have found is KWC America 504 938 000 Primo Lotion Soap Dispenser on amazon. I hope this was helpful, cheers
Feb 16, 2009 | Delta RP1001-BL Classic Kitchen...
Bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Grohe Satin Nickel Soap Dispenser...
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Home Logo
397 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
