Question about Nextar GPS
Power cord shorts - Nextar GPS
  • 356 Answers
Buy a replacement power cord from Nextar
Posted on Oct 19, 2013
When i switch on the fuse bursts
Shorted component/s at its main power regulator [SMPS] board. Check and replace them, or replace the SMPS board as card basis.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Apr 02, 2015 | Televison & Video
B&D Electric drill model DR501 Type1: Power cord
Maybe the motor was damaged by the short.
Oct 31, 2013 | Drills
Power supply fuse blows
either shorted cord or bad power supply if only when unit in water shorted cord or bad motor
Jun 24, 2013 | Aquabot Pool & Spa
How to check wiring inside a cobra 25 classic to determine if its made propperly
Yes, if you have a meter check resistance (like reading a fuse) with the radio off and power cord removed.
Only two of the three pins (look at power cord to see only two have metal in them) are used.
With power switch on front in off position there should be no reading across the + to - pins on the back of the radio.
If a short there the protect diode is shorted--likely first time it got hooked up backwards--easy to do.
Follow in this case the + pin on back just inside the radio and it goes directly to a diode. cut the diode if a short there and read again at the plug--if short gone replace the diode--radio will work without it but you will have no protection in that case.
Jun 02, 2012 | Cobra 29 LTD CB Radio
How do i fix my nintendo 64 when it has a short in the power chord?
If you're sure that the short is in the power cord, you can replace the cord to get the Nintendo to work. You can find replacement cords on eBay -- here are some that are for sale now:
Jun 26, 2010 | Nintendo 64 Console
I need to move the power cord from floor to ceiling
I would recomend you purchase a "heavy duty" (12 guage) short extension cord for appliances. You could remove the face cover and modify the unit so the cord goes up but I don't think it will be much longer nor will it be as safe. The cord has a moulded gromet mad onto it so you may only be able to move it to the side. You would have to make a similar mount on the unit (cutting metal and plastic parts to hold the cord properly. The short HD cord will not cause any loss in the units operation,warranty or unit life.
Aug 04, 2009 | LG Art Cool LA121HNP Split System Air...
Power cord shorts out
Three possible issues,
1. the cord is bad, to test this go to local PC shop and buy a universal power cord test it with this cord. If it works then your cord was bad and you have purchased the correct part. If it doesnt work return cord for a refund.
2. The connector inside the laptop that the power cord connects to is loose and has a short in it. If its loose take it to a PC Shop that knows how to solder and have them reconnect it securely.
3. The laptop has incurred internal damage possibly from a fall or ruff handling. If this is the case the Motherboard may need to be replaced. If this is the case consider purchasing a new laptop.
Hope this helps,
Feb 26, 2009 | Dell Inspiron B120 Notebook
Power problem
I don't think you are dealing with a short in your system. Your battery is probably dead and/or needs to be charged. See if your new power cord will work and will turn your computer on. Make sure that you have the exact power cord that your specific system calls for, because not all laptop power cords are the same. I mean you can't just use any laptop power cord; it has to be one that is rightly built specifically for your laptop system.
Sep 03, 2008 | Acer Aspire 7720 Notebook
GPS Logo
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
