Question about Bosch Nexxt DLX WFMC4301UC
Door catch doesn't line up with receiving slot, it hits the bottom of slot, can lift door slightly to close
  • 90 Answers
The machine needs rebalance.
1. Get a level.
2. Learn how to use a level.
3. Watch this video how to do it on a washer
Posted on Oct 18, 2013
Testimonial: "thanks for the idea, but it is level already"
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
Driver door doesn,t close
If you look at the latch mechanism on the door you will see a slotted piece that will line up with the latch receiver on the door post. When the door is open, this slot should be turned so that it can grab the receiver when you close the door. Try moving it into the proper position while manually pulling the door open handle.
Mar 06, 2015 | 2001 Audi TT
How to change radiator on 98 buick park avenue
Pretty straight forward on this one. You will want to remove the top mounts and make sure all hoses and lines are unhooked. You might need to remove the electric cooling fan assembly off of the radiator to make enough room, but the radiator will lift straight up and out.
Oct 12, 2012 | 1998 Buick Park Avenue
My frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
Apr 24, 2012 | Frigidaire Refrigerators
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When I pull the hood release, the hood doesn't pop up. I either have to have a second person lift slightly on the hood while I pull the release, or I have to wedge something under the edge of the hood...
No the bumpers don't do that. After time it seems the latch itself bends. Look at it and see where it is hitting. There is some adjustment in the catch at the bottom/grill. But I usually just bend the latch left or right as needed. You can use a pry bar to bend it or just hit it with a hammer. Be careful not to hit the hood.
Sep 09, 2011 | 1999 Mazda 626
How do you adjust car door that needs to be sort of lifted to close. noemally, it gets slammed shut a couple of times to close right.
The usual cause of a hanging door is a worn door hinge or two. You might be able to loosen and lift the two hinges, at the front of the door, a bit.That might allow the door to close better but the best solution is to replace the worn hinges.
Jan 14, 2011 | 1998 Chevrolet Blazer
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
Drivers side door will not catch when door is closed it will just bounce away. the door handle does not seem to be as spring loaded as passenger side thanks
Look on the end of the door and you will see the slot where the door catch is located. It should line up with a big stud sticking out from the post by the drivers seat. The gap should be open. If you see a piece of steel blocking the slot, then the door catch is already in the latched position. Insert a screwdriver into the bottom of that catch and pull it up into the open position. If that is the problem, the door will work after that. Hope that helps
Jan 01, 2010 | 1990 Buick Reatta
Battery in M-RBB93
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, close the battery door.
regards
Feb 21, 2008 | Logitech Cordless Mouse
Bosch Nexxt  DLX WFMC4301UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
