Question about Dirt Devil 0100 Handheld Bagless Vacuum Cleaner
The belt won't stay on! I put it onto the silver piece that spins...as soon as I turn it on to test it it comes off...the brush doesn't spin...Am I missing a part??
    Master:
  • 452 Answers
Cathy
The brush roller only sits one way and must b free rotating not jammed up if roller is tight to turn disassemble and clean it when u put it back after u have put belt on turn by hand to see if it stays on, if it does ok done .
Cathy theirs ,
only to things that will cause this the brush roller running out of square, or jammed up and makes the belt jump of.
Posted on Oct 18, 2013
Beater bar on electrolux el8602
Usually you have to replace the belt or if it is burning up belt take beater bar out and check the ends to see if they turn. Sometimes they get thread up in them from carpet and get stuck from turning and then they will burn belt up. Rich
Dec 21, 2014 | Electrolux El8502a Versatility Bagless...
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
I have an Ionic Breeze Quadra Silent Air Purifier, Sharper Image Design. Model S1637 one of pieces came off, it is one that is held on by a thin silver wire. How do we repace it or put it on. Thank...
Hello there, sorry but there are several pieces on this unit which could pull off. Here is a user guide to help you determine which of the parts exactly you are referring to.Please try to determine which part exactly it is or just get a picture sent to me to enable me determine the exact part.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Sep 02, 2011 | Sharper Image Professional Plus Ionic...
Rainbow rainmate broken.
You can do one of two things: order a new spin wheel from ainbow, or you can go to Lowe's or home Depot and get a product called GOOP. Get Marine Goop if the store has it. Put toe Goop on the edges of the broken parts and let it set a minute and then put the two broken pieces together. Spread a thin layer of GOOP over the crack onto both broken parts and let is set about ten minutes or so while you hold them. set the part down in a way that doesn't throw the parts off kilter and let them dry overnight. Problem should be fixed.
Mar 18, 2009 | Rainbow Rainmate Air Purifier
Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
Nov 12, 2008 | Oreck (AIRCOM1WOI) Air Purifier
Dirt Devil 0100 Handheld Bagless Vacuum Cleaner Logo
90 people viewed this question
Top Dirt Devil Air Purifiers Experts
Vernon Taylor
Ross Stacey
Level 1 Expert
Tom Chichester
Are you a Dirt Devil Air Purifier Expert? Answer questions, earn points and help others
