Question about Toshiba 61H70 61" Rear Projection Television
Jittering screen Our rear projection Toshiba's picture has started to jitter and shake. We're also getting double picture on the right part of the screen. We'd appreciate your help. Thanks.
  • dawidshalom Mar 24, 2008
    my zenith tv screen is jittering horizontally,when i turn it on; the top part of the screen and the bottom part is both blue,and the middle part is the only part showing jittery.after a few minutes i will get the full screen,but it jitters back and forth.
    Genius:
  • 1,694 Answers
Chassis will need to be pulled by a skilled technician.Some specific area hand-soldering is needed and the STK convergence IC's need changing w/OEM or better quality parts.You have a good set worthy of repair.
Posted on Sep 26, 2007
SOURCE:
Soyo DYLM1988 vertical hold/jittering picture problems when starting up. Clears when warmed up & playing with monitor settings helps.
How old is the screen? if more than 5 years, the circuitry can go bad. I had this with one of mine, it would jitter for about 10 mins before it warmed up. Just get a new one, they are cheap as chips
Sep 27, 2017 | Soyo DYLM1988 Monitor
Picture shakes
To help you I need to know the set is a 42mf7000 and which direction does it shake or jitter= up/down OR left/right?
Mar 15, 2012 | Televison & Video
When turned on picture was unstable (Jittering) for some time. Now when turned on the power indicator light comes on then blinks. No operation or display. I can't locate a repair for this unit in...
Depending on your Toshiba model this may be an issue with the hypermodule. When it fails it will make the TV zig zag looking. One quick test is to see if your picture-in-picture window looks normal. If so the hypermodule is the issue. You can google Z1234TV to locate parts.
Nov 05, 2011 | Toshiba 53H71 53 in. Rear Projection...
Sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Jul 22, 2009 | Sony HDR-CX7 Camcorder
Shaking
On the power supply PCB are two 220uf 25V capacitors that will be leaking. Replace both and the picture will return to normal.
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Issues with the big screen
This is essentially a convergence problem and will continue to get worse. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted on your progress.
Dan
Jul 14, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Akai pdp 4273m 42
I cured the problem by placing a fan in front of the screen that not only blows directly on the LCD screen, but also air underneath the screen providing circulation around the entire unit. Apparently the LCD screen is overheating causing it to "trip". I can stop the blower after about 20 minutes and there is no problem.
I will never buy another Westinghouse product again as long as I live.
Oct 15, 2007 | Televison & Video
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
