Question about Toshiba Satellite Computers & Internet
Uac disabled; how to enable please I cant download
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 225 Answers
Http://windows.microsoft.com/en-au/windows-vista/turn-user-account-control-on-or-off
Posted on Oct 21, 2013
2 Suggested Answers
jadiazq
  • 2878 Answers
SOURCE: I run on windows vista 7 starter, I cant download and when I Do I get a message that says service is disabled or hos no enabling devices. Can I find some help here, I'm not too savvy on pc's
Stopped using download applications all together, since I no longer use dial-up. But, there is a Free Download Manager if you still require one.
Posted on Nov 23, 2012
How to disable uac
User account control?
Google search UAC or disable user account control
May 15, 2013 | Gateway GT5692 Desktop Computer
Tip
Using UAC in Windows Vista
Windows Vista has the built-in ability to automatically reduce the potential of security breaches in the system. It does that by automatically enabling a feature called User Account Control (or UAC for short). The UAC forces users that are part of the local administrators group to run like they were regular users with no administrative privileges.
Although UAC clearly improves the security on Windows Vista, under some scenarios you might want to disable it, for example when giving demos in front of an audience (demos that are not security related, for example). Some home users might be tempted to disable UAC because of the additional mouse clicking it brings into their system, however I urge them not to immediately do so, and try to get used to it instead.
Anyway, if required, you can disable UAC by using one of the following methods:
Method #1 - Using MSCONFIG
  1. Launch MSCONFIG by from the Run menu.
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  3. Press the Launch button.
  4. A CMD window will open. When the command is done, you can close the window.
  5. Close MSCONFIG. You need to reboot the computer for changes to apply.
You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
*Recommended: Speed up Vista boot times by reducing the number of programs that load at startup. Control your Vista startup list with this Vista app
Method #2 - Using Regedit
  1. Open Registry Editor.
  2. In Registry Editor, navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
  3. Locate the following value (DWORD): EnableLUA and give it a value of 0.
    disable_uac_2.gif Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
  4. Close Registry Editor. You need to reboot the computer for changes to apply.
In order to re-enable UAC just change the above value to 1.
Method #3 - Using Group Policy This can be done via Local Group Policy or via Active Directory-based GPO, which is much more suited for large networks where one would like to disable UAC for many computers at once.
If using Local Group Policy you'll need to open the Group Policy Editor (Start > Run > gpedit.msc) from your Vista computer.
If using in AD-based GPO, open Group Policy Management Console (Start > Run > gpmc.msc) from a Vista computer that is a member of the domain. In the GPMC window, browse to the required GPO that is linked to the OU or domain where the Vista computers are located, then edit it.
  1. In the Group Policy Editor window, browse to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options.
  2. In the right pane scroll to find the User Access Control policies (they're down at the bottom of the window). You need to configure the following policies:disable_uac_gpo_2.gif
  3. You'll need to reboot your computers.
Method #4 - Using Control Panel
  1. Open Control Panel.
  2. Under User Account and Family settings click on the "Add or remove user account".
  3. Click on one of the user accounts, for example you can use the Guest account.
  4. Under the user account click on the "Go to the main User Account page" link.
  5. Under "Make changes to your user account" click on the "Change security settings" link.
  6. In the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
  7. You will be prompted to reboot your computer. Do so when ready.
In order to re-enable UAC just select the above checkbox and reboot.
on Apr 29, 2010 | Microsoft Windows Vista Home Premium...
What i can do for error 0001 0005 can u give me a description of that problem
This error is returned when activating the product.
In order to solve the problems related to the error code 0001:0005 during the activation procedure, the option UAC (User Account Control) protection must be disabled. This solution is only applicable to Microsoft Windows Vista operating systems:
Note: Disabling UAC will lead to a less secure system, so don´t forget to re-enable the UAC option as indicated in the instructions.
Next to solve the problem follow the instructions below:
  1. Access the Control Panel.
  2. Type in UAC in the search box and click Enter.
  3. In User accounts, click the link Turn User Account Control (UAC) on or off.
  4. On the next screen, uncheck the box Use User Account Control (UAC) to help protect your computer. Then, click OK.
  5. IMPORTANT: reboot your computer for the changes to take effect.
Dec 13, 2010 | Epson 9880 stylus pro Printer
I have a fejl code 646, and i dont no whot to do
Step 1: Turn off UAC (use MSCONFIG)
1. Click Start. Type MSCONFIG in the Start Search bar and press Enter.
Note: If UAC window prompts for permission to continue, please click Continue.
2. Click Tools.
3. Highlight Disable UAC, click Launch.
4. Restart the computer and test the issue again.
Note: If you turn on UAC, please launch Enable UAC
If the steps do not work, let's refer to the following steps to manually download and install the updates.
Manually download and install updates
1. Visit Microsoft Download Center: http://www.microsoft.com/downloads
2. Use the IDs of Windows Updates to find the download links. For example, you can use the key word KB972363 to find the link to download update 972363.
3. Download updates from the links and save them to the desktop. Double click on the installation files and install the updates manually.
Dec 01, 2010 | Microsoft Windows Vista Home Premium with...
I inadvertantly disabled my Cap Locks and I cannot figure out how to enable them again. When in Microsoft Word, if I double click on the greyed-out CAPS in the lower right hand corner, it will turn the Cap...
Click on the link below to download theEnable_Caps_Lock.reg file. http://www.vistax64.com/attachments/tutorials/5550d1217920203-caps-lock-key-enable-disable-enable_caps_lock.reg
Right click on the .reg file (destination where saved after download) and click on Merge to add it to your registry.
Click Run button in the Security Warning prompt.
Click on Continue in the UAC prompt.
Click Yes in the confirmation prompt.
Click OK in the success prompt.
restart the computer to apply the fix
now u can delete the file .reg file (destination where saved after download)
DO REPLY AND RATE ME PLEASE!
Jul 09, 2010 | Microsoft Works 9 for PC
Getting lines and frozen screen when my asus x58l is moved please help
Please disable the UAC feature and reinstall the Video Driver. you can disable the UAC by following:
Jun 30, 2010 | ASUS Eee PC 701 Notebook
I keep getting a message internet explorer has stopped working
I have seen this issue several time and have owned the same laptop. This is how i fixed the issue that you are having. I disabled the User account controls. Im not sure what operating system you are using i will show you how to turn of UAC on both windows vista and windows 7
WINDOWS VISTA
  1. Launch MSCONFIG by the Run menu or search.
  3. Press the Launch button A CMD window will open. When the command is done, you can close the window.
  4. Close MSCONFIG. You need to reboot the computer for changes to apply.
  5. You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
    WINDOWS 7
    Go to User Account Control Settings.
    Type in UAC, or go to the System and Security applet. Click on the "Change User Account Control Settings" link.714e9df.pngTo turn off UAC, move the slider to the Never notify position, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.865b1d3.pngTo turn UAC back on, move the slider to choose when you want to be notified, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    You will need to restart your computer for UAC to be turned off.
    This should help cure your problem. Hope this helps you.
Jun 23, 2010 | HP Pavilion dv6000z Notebook
When I try to open Home Budget for Dummies, I get a message that says "This application requires using the 4.73 help system or a more recent version". Is there something I can download to fix this? I don't...
What kind of operating system you have?Is it vista?If so, try to install the latest Service Packs on the computer.If it cant resolve the problem try to disable your UAC setting then reboot it and Reinstall your software.Here is the link on how to disable your UAC http://www.vista4beginners.com/How-to-disable-UAC
Nov 07, 2009 | Anuman Interactive Home Budgets for...
How to disable uac to install windows vista themes
click on start
Type in start search "msconfig" and press enter.
Now system configuration will open
Now click on the "Tools" tab
Now scroll the list down and click on "Disable the UAC"
Restart computer
To enable again follow above procedure but select Enable UAC and restart computer. All the best
Jul 11, 2009 | Computers & Internet
Internet problem
Most likely your UAC (User Account Control) is preventing you from running the program. You should receive a prompt asking for permission to run thr program unless you've inadvertenly given Vista control to block access to add on programs. It's possible to disable UAC (temporarily or permanantly) by doing the following Start/ControlPanel/Security/SecurityCenter click on "Other Security Settings" to turn off UAC. You should then be able to run the desire program (make sure u trust the program you're installing). You can always repeat the process to enable UAC after.
Apr 23, 2009 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
