Question about Saws
Pyrotronics cp30 manuel
What is the trigging output on a CP-31
    Sergeant:
  • 468 Answers
Make a quick search on google.
Posted on Oct 18, 2013
How come when i try to do inverse trig function on my fx-9750 gii calculator it says Ma error?
Just wondering if the other functions are working.
The manual references setting up angle unit and setting up the "comp for mode" in the setup.
The keys you should be pressing to do this calculation are on page 51 (2-31) of the attached manual.
http://support.casio.com/manualfile.php?rgn=5&cid=004002013
Good luck. If unsuccessful, please repost.
Paul
Nov 03, 2016 | Casio FX-9750GII Graphing Calculator
WHAT IS THE MEANING OF FAULT CODE 21,24 AND 31
21 - VANOS solenoid activation, intake Output digital pulse width (active low)
DME final stage will set flag
whenever a short to ground, a short
to battery voltage or a disconnection
between output transistor and
component exists.
24 - Injector circuit cyl. 4 Output digital pulse width (active low)
component exists.
31 - Ignition coil cyl.5 Input analog timing
DME initiates secondary ignition for
(100 mV) each cylinder then looks for feedback
through shunt resistor in harness to
determine if ignition actually occurred.
Oct 12, 2015 | Cars & Trucks
My car toyota srs porablm
air bags
get the bags scanned,
read the FSM on bags yet< (factory service manual)
or at alldata.com, DIY.
in what country? , did you read the TSB recall yet>?????
huge recall.
where is this 31 code? at>?
Trouble Code: B1000/31 (1.8L L4 VIN R Auto)
Airbag ECU Malfunction * Airbag sensor assy center
remove battery neg lug before touching any SRS parts.
B1000/31; Center Airbag Sensor Assembly Malfunction (2006 Corolla From 07/2005) DESCRIPTION The center airbag sensor assembly consists of a deceleration sensor, safing sensor, drive circuit, diagnosis circuit, ignition control, etc.
If the center airbag sensor assembly receives signals from the deceleration sensor, it determines whether or not the SRS should be activated.
DTC B1000/31 is recorded when a malfunction is detected in the center airbag sensor assembly.
If only DTC B1000/31 is output, do not clear the DTCs, replace the center airbag sensor assembly.
If any DTCs other than DTC B1000/31 are also output, troubleshoot those DTCs first.
use a real scan tool
and see all errors.
if not you guess wrong.
Feb 02, 2015 | 2006 Toyota Corolla
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
This calculator is really confusing, i would like to know how to use its trig functions
To use the trig functions simply press the button with the trig function you want and then type in the value of the angle. If you want to add or subtract thing within the angle remember to put open and close ( ) brackets around the angle.
If you have any other calculator questions dont forget to check out Welcome to Maths at SHARP Maths at Sharp
The website also has a manual available to download.
Feb 24, 2014 | Sharp ELW535 Calculator
Father-in-law has a Rinnai REH-20D-N model and needs two parts: CP-80037-31 and REH19D-20. Where can I get parts?????
Rinnai, the manufacturer can help you. Go to http://www.rinnai.us/ for more info and contact information.
Jan 21, 2011 | Heating & Cooling
I have a hq-31 mono 31 band eq with feedback
first connect your sound source(dvd player-vcr-...)to eq-input-------eq output--------line in in mixing desk.
Oct 13, 2009 | Audio Players & Recorders
Inverse Functions on Casio fx-270W PLUS don't seem to work
because cotangent, cosecant, and secant are all inverse trig functions, just type in 1 / |shift| trig function and the number if you are finding the angles. It might not be a dedicated button, but its an extra push, and it will give you the same result. *note that I put the shift press only because that is how you get the inverse tan to get an angle from a tan ratio.*
May 04, 2009 | Casio FX-270W Calculator
Trig functions of the TI-30XA
if the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
May 09, 2008 | Texas Instruments TI-30XA Calculator
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Saws Logo
87 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
