Question about Samsung 46 UN46D7000 3D LCD TV
Hi I have UND7000 series. I am givign my home network credentials in network settings menu in tv. its accepting the credentials and says conencted sucessfully. but when i exit the settigns menu and come back to the display and try to connect to youtube or google or any sit on network. its says network credential are not set. When i go and check under network settings , indeed the credentials i supplied are not there and the TV is nto connected to network. It seems the network connectivity settings are not being saved even though i am saving it. Is there any solution? Do I need to update the software of this TV?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
Firmware update
Posted on Oct 18, 2013
SOURCE: Trouble connecting DVD
NEWER TV SETS REQUIRE THE RIGHT CABLES, USE S-VIDEO OR AN HDMI CABLE WILL SOLVE ANY PROBLEM
ALSO SOME T.V SETS ARE JUST LIKE THE PLUG AND PLAY YOU HAVE WITH COMPUTERS, ONCE THE RIGHT CABLE IS CONNECTED AND YOU CHANG TV INPUT FROM YOUR REMOTE IT WILL PICK UP YOUR DVD
Posted on Jan 21, 2009
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
  • 92 Answers
SOURCE: Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Posted on Mar 28, 2009
  • 1043 Answers
SOURCE: When I connect my Toshiba Satellite Laptop to my
I had the same issue with my laptop after I upgraded my video driver. Check on the Toshiba website for the correct display driver for your laptop and download it. Follow their directions and install it on to your hard drive. If it is the same driver that came with your laptop originally, the default settings should allow you to connect back to your LCD TV and get the proper display. If that doesn't work you will probably have to call Toshiba support and ask them for the default settings.
Posted on Jul 07, 2009
  • 127 Answers
SOURCE: I have a Samsung Series 6-650 LCD TV (Model #
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Posted on Mar 02, 2010
How to install prophet bushiri channel on dstv
PROPHETIC CHANNEL SETTINGS on Your DECODER(DSTV)
Step: 1 Press menu Select "Advanced Options" Select "Dish Installation" Enter the pin "9949"
Select "Network Configuration" Select "Network 2 Setup" NB: Leave "Network 1 Setup (Home)" unchanged!! Set Signal Setup to "Enabled" by selecting it, and moving left or right Set Frequency to "11170" Set Symbol Rate to "26652 Set Polarization to "Vertical" Set FEC to "3/4? Select "Accept these settings"
Step: 2 Select "Network 2 Setup" Set Signal Setup to "Enabled" Set Frequency to "12682" Set Symbol Rate to "26657 Set Polarization to "Horizontal" Set FEC to "1/2? Select "Accept these settings"
Step: 3 Select "Network 3 Setup" Set Signal Setup to "Enabled" Set Frequency to "12722" Set Symbol Rate to "26657 Set Polarization to "Vertical" Set FEC to "1/2? Select "Accept these settings"
Step: 4 "Accept these settings" to go back to the "Dish Installation" menu then Select "Scan All Networks" Your decoder will go into scanning mode and might take a while to scan all networks. Do not interrupt the process even if it seams to take longer than you expected! Once completed, your picture will return as normal.
ENJOY WATCHING PROPHETIC CHANNEL.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Nov 19, 2016 | Televison & Video
How do I connect Samsung LAN adapter WIS09ABGN to the network?
Plug it into one of the TV's USB ports, then configure your network's credentials (SSID, encryption type and passphrase) from the network setup menu in your TV.
Aug 02, 2013 | Samsung WIS09ABGN WIRELESS LINKSTICK...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
How can I connect the RMC30C1 Samsung Remote COntrol to my Samaung 8000 Series TV
No simple answer. I have the series 9 samsung.
Basically you need to connect the tv to the internet, and the remote control to the internet and then connect the remote to the tv. There are a few other ways but this is what I did for my Series 9 TV: Before you start check your wireless internet security number for your broadband router. If unsure check the instructions that came with your wireless router as you will need to type in the internet address and setup wireless security key, otherwise your exposed to other people using your broadband download.
Step One: Menu setting on TV go to PlugPlay- Network - set it up. To find Menu TV Control on remote, flick your finger right to left to scroll to new hidden screen - menu appears! Step Two: Test network connection, (you should set up wireless security (WEP/WAP) to match your broadband security key) Step Three: Services Tab/Setting icon/remote settings/network/wait until it finds network/select network/add security internet WEP/WAP Key - check IP Service Provider if unsure. When Remote is connected to the internet tap bottom right button to connect tv. Tab appears on the tv 'allow or not allow remote' select allow using the TV navigation button. Simple really. Mike
Jan 11, 2011 | Samsung RMC30C2 Remote Control
How to get phone on home internet
1. Click Set Up Wi-Fi.
2. Click Next.
3. Click Manually Add Network.
4. Type the network name or service set identifier (SSID).
5. Click Add.
6. From the Security Type menu, select the security type for
the Wi-Fi network.
7. Specify the required security credentials.
8. Click Connect to manually add and connect to a Wi-Fi
network.
Jan 05, 2011 | AT&T Blackberry Curve 8300 Smartphone
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
My toshiba satellite laptop won't connect wirelessly to Bigpond home network gateway. Bigpond reckon it's a toshiba problem
As a general test, see if you can ping the "router's configuration URL IP address". To do that go to a command prompt(DOS Prompt) and type in ping and the routers IP. If you get replies you are OK conencting as far as the router. Next try PINGing to www.yahoo.com or www.google.com. If you get replies you are OK conencting as far as the Internet. If not try sending a ping to their IP(the numbered) address. If you get replies you are OK conencting as far as the Internet, but you have a DNS issue. Big Pond can help you with that.
Nov 20, 2009 | Toshiba Satellite Pro P300 Notebook
My ausus eee pc series netbook wont connect to the internet what can ido ?
OK - I just went through 2 hours of madness to finally get this going on mine as well - here's what you need to do.
1. Go to your router settings (security) and if you have WEP enabled, change that to WPA (this is a better security anyway)
Follow this - step by step:
2. double click on your wireless icon (lower right corner of windows) - this will open up the "Wireless Network Connection Status"
3. click "View Wireless Networks" - you'll see all available
4. on the menu items to the left, click on "Change Advanced Settings"
5. pops up the Wireless Network Connection Properties window
6. Click Wireless Networks tab
7. click on your home network, or whichever one you normally connect to
8. when it's highlighted, click "Properties"
9. Make sure that the WEP is NOT selected, and select WPA
10. when you go to connect, it will again ask for your credentials - enter it, it should start checking acquiring network address...and you should get connected.
By the way, I tried updating drivers - restarting, moving closer, blah blah - waste of time. Changing the protocol from WEP to WPA did the trick, but remember you have to do it on the router AND your netbook.
if this helps, shoot me a "positive" on the feedback!!
on your netbook, go into your "view wireless networks" - choose the one that you normally use, for example, your home wireless network
Oct 26, 2009 | ASUS Computers & Internet
My son is home visiting and cannot connect to our high speed internet. It must be something on his computer, as my computer when I hook it up works just fine. Can you help me out? Thanks... Pat
This may be due to many reasons.
Firstly, you may be trying to connect both machines on the net within a short time interval... normally ISPs don't allow this to happen, as they want to connect only one PC to one home type connection. Try connecting your son's PC after disconnecting your PC for atleast 1 hour. :)
Also, try to check the settings on your son's PC...it may not be having proper settings for accepting a new network conenction due to some settings of security softwares installed.
If everything is OK and still you are not able to connect, please don't feel shy to call your ISP for a rational explanation.
bye
Have a nice day
Jul 21, 2008 | Computers & Internet
Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Jun 15, 2008 | Audio Players & Recorders
Samsung 46 UN46D7000 3D LCD TV Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
