How to enable uac - Computers & Internet
    Scholar:
  • 145 Answers
UAC should be enabled by default, if you have it turned off then to turn it back on go to Control Panel and in the search box type uac then click Change User Account Control settings, the slide the slider up to when you want to notified.
Posted on Oct 18, 2013
    Champion:
    Habit-Forming:
  • 245 Answers
User Account Control (UAC) can help you prevent unauthorized changes to your computer. It works by prompting you for permission when a task requires administrative rights, such as installing software or changing settings that affect other users.
We don't recommend turning User Account Control off. If you do turn it off, you should turn it back on as soon as possible.
  1. Open User Accounts by clicking the Start button how to enable uac - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking User Accounts and Family Safety(or clicking User Accounts, if you are connected to a network domain), and then clicking User Accounts.
  2. Click Turn User Account Control on or off. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Select the Use User Account Control (UAC) to help protect your computer check box to turn on UAC, or clear the check box to turn off UAC, and then click OK.
How to enable UAC
Hello Anon,
Click on the "Start" or the "Windows" button and in the search box type UAC and in the results you will find "Change user account control settings".
Regards,
Ron.
Jun 06, 2014 | Computers & Internet
Tip
Using UAC in Windows Vista
Windows Vista has the built-in ability to automatically reduce the potential of security breaches in the system. It does that by automatically enabling a feature called User Account Control (or UAC for short). The UAC forces users that are part of the local administrators group to run like they were regular users with no administrative privileges.
Although UAC clearly improves the security on Windows Vista, under some scenarios you might want to disable it, for example when giving demos in front of an audience (demos that are not security related, for example). Some home users might be tempted to disable UAC because of the additional mouse clicking it brings into their system, however I urge them not to immediately do so, and try to get used to it instead.
Anyway, if required, you can disable UAC by using one of the following methods:
Method #1 - Using MSCONFIG
  1. Launch MSCONFIG by from the Run menu.
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  3. Press the Launch button.
  4. A CMD window will open. When the command is done, you can close the window.
  5. Close MSCONFIG. You need to reboot the computer for changes to apply.
You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
*Recommended: Speed up Vista boot times by reducing the number of programs that load at startup. Control your Vista startup list with this Vista app
Method #2 - Using Regedit
  1. Open Registry Editor.
  2. In Registry Editor, navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
  3. Locate the following value (DWORD): EnableLUA and give it a value of 0.
    disable_uac_2.gif Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
  4. Close Registry Editor. You need to reboot the computer for changes to apply.
In order to re-enable UAC just change the above value to 1.
Method #3 - Using Group Policy This can be done via Local Group Policy or via Active Directory-based GPO, which is much more suited for large networks where one would like to disable UAC for many computers at once.
If using Local Group Policy you'll need to open the Group Policy Editor (Start > Run > gpedit.msc) from your Vista computer.
If using in AD-based GPO, open Group Policy Management Console (Start > Run > gpmc.msc) from a Vista computer that is a member of the domain. In the GPMC window, browse to the required GPO that is linked to the OU or domain where the Vista computers are located, then edit it.
  1. In the Group Policy Editor window, browse to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options.
  2. In the right pane scroll to find the User Access Control policies (they're down at the bottom of the window). You need to configure the following policies:disable_uac_gpo_2.gif
  3. You'll need to reboot your computers.
Method #4 - Using Control Panel
  1. Open Control Panel.
  2. Under User Account and Family settings click on the "Add or remove user account".
  3. Click on one of the user accounts, for example you can use the Guest account.
  4. Under the user account click on the "Go to the main User Account page" link.
  5. Under "Make changes to your user account" click on the "Change security settings" link.
  6. In the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
  7. You will be prompted to reboot your computer. Do so when ready.
In order to re-enable UAC just select the above checkbox and reboot.
on Apr 29, 2010 | Microsoft Windows Vista Home Premium...
How DO I Enable A UAC?
Hi Tammy,
Open the Devices and Printers Folder. Right click on the Printer icon and click Troubleshoot and follow the instructions. Hope this helps.
Regards,
Sean
Jun 03, 2014 | Office Equipment & Supplies
What i can do for error 0001 0005 can u give me a description of that problem
This error is returned when activating the product.
In order to solve the problems related to the error code 0001:0005 during the activation procedure, the option UAC (User Account Control) protection must be disabled. This solution is only applicable to Microsoft Windows Vista operating systems:
Note: Disabling UAC will lead to a less secure system, so don´t forget to re-enable the UAC option as indicated in the instructions.
Next to solve the problem follow the instructions below:
  1. Access the Control Panel.
  2. Type in UAC in the search box and click Enter.
  3. In User accounts, click the link Turn User Account Control (UAC) on or off.
  4. On the next screen, uncheck the box Use User Account Control (UAC) to help protect your computer. Then, click OK.
  5. IMPORTANT: reboot your computer for the changes to take effect.
Dec 13, 2010 | Epson 9880 stylus pro Printer
I have a fejl code 646, and i dont no whot to do
Step 1: Turn off UAC (use MSCONFIG)
1. Click Start. Type MSCONFIG in the Start Search bar and press Enter.
Note: If UAC window prompts for permission to continue, please click Continue.
2. Click Tools.
3. Highlight Disable UAC, click Launch.
4. Restart the computer and test the issue again.
Note: If you turn on UAC, please launch Enable UAC
If the steps do not work, let's refer to the following steps to manually download and install the updates.
Manually download and install updates
1. Visit Microsoft Download Center: http://www.microsoft.com/downloads
2. Use the IDs of Windows Updates to find the download links. For example, you can use the key word KB972363 to find the link to download update 972363.
3. Download updates from the links and save them to the desktop. Double click on the installation files and install the updates manually.
Dec 01, 2010 | Microsoft Windows Vista Home Premium with...
Getting lines and frozen screen when my asus x58l is moved please help
Please disable the UAC feature and reinstall the Video Driver. you can disable the UAC by following:
Jun 30, 2010 | ASUS Eee PC 701 Notebook
I keep getting a message internet explorer has stopped working
I have seen this issue several time and have owned the same laptop. This is how i fixed the issue that you are having. I disabled the User account controls. Im not sure what operating system you are using i will show you how to turn of UAC on both windows vista and windows 7
WINDOWS VISTA
  1. Launch MSCONFIG by the Run menu or search.
  3. Press the Launch button A CMD window will open. When the command is done, you can close the window.
  4. Close MSCONFIG. You need to reboot the computer for changes to apply.
  5. You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
    WINDOWS 7
    Go to User Account Control Settings.
    Type in UAC, or go to the System and Security applet. Click on the "Change User Account Control Settings" link.714e9df.pngTo turn off UAC, move the slider to the Never notify position, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.865b1d3.pngTo turn UAC back on, move the slider to choose when you want to be notified, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    You will need to restart your computer for UAC to be turned off.
    This should help cure your problem. Hope this helps you.
Jun 23, 2010 | HP Pavilion dv6000z Notebook
How to disable uac to install windows vista themes
click on start
Type in start search "msconfig" and press enter.
Now system configuration will open
Now click on the "Tools" tab
Now scroll the list down and click on "Disable the UAC"
Restart computer
To enable again follow above procedure but select Enable UAC and restart computer. All the best
Jul 11, 2009 | Computers & Internet
Internet problem
Most likely your UAC (User Account Control) is preventing you from running the program. You should receive a prompt asking for permission to run thr program unless you've inadvertenly given Vista control to block access to add on programs. It's possible to disable UAC (temporarily or permanantly) by doing the following Start/ControlPanel/Security/SecurityCenter click on "Other Security Settings" to turn off UAC. You should then be able to run the desire program (make sure u trust the program you're installing). You can always repeat the process to enable UAC after.
Apr 23, 2009 | Dell Dimension 3000 PC Desktop
Vista not recognizing driver from usb g220
Try turning off the Vista security feature known as User Account Control (UAC).
Go into Control Panel/Users. Select your own account then click the link on the left "turn UAC on or off". Disable UAC then click Apply/OK.
Now try installing the driver again. If you still get the "digital signature" warning choose the option to "install anyway".
The driver should then load. You would be best advised to re-enable UAC after you have finished loading the driver.
Jan 03, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
