Question about Topcase Rack BMW F650GS, 08- & F800GS, 08-
I have a f800gs bmw.floating disks on front wheel very loose and is irritating.Could the 650 daker front disk be fitted on my 21" front rim?ineed to fit two.
  • 103 Answers
Is irritanting where applying the brakes? Or just because are loose when you touch them? If is the second one is normal for disks to move a little. If braking is not affected don't worry. Just check the disks with some gloves after a ride when the brakes are hot. You will see that the disks are tighter than cold.
Posted on Oct 21, 2013
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
F800gs,can the front discs made solid like the 1200gs front discs?
There are all sorts of high performance rotors for this bike on line and through BMW.
https://www.google.com/search?q=F800gs&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=F800gs+front+rotors&rls=org.mozilla:en-US:official&tbm=shop
Oct 10, 2013 | Topcase Rack BMW F650GS, 08- & F800GS, 08-
My 2007 BMW G650XChallenge rear wheel starts to bounce at around 100kph,the faster you go the worse it gets, have had the wheel balanced tried different pressures, different tyres and adjusted preload...
Hi, Alex I feel your pain perhaps something on this list may help point you in the right direction and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
2007 BMW Xchallenge Xcountry Motorcycle USA
Thread The BMW 650 Country
2001 2005 BMW F650CS Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Nov 12, 2012 | 2007 BMW G 650 Xchallenge
2004 BMW R1200CL Loose rear brake disk
Have you changed the pads lately sometimes when they wear down it couses diske to get loose meaning you need to check it.
I had the same problem and thats what it was
Jul 26, 2012 | Cars & Trucks
Bmw f800gs starts and stalls after 3 seconds
Hi, Eddie the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
F800GS stalling cutting out help Horizons Unlimited The HUBB
F800GS Stalling AGAIN
https://www.tradebit.com/filesharing.php/search/0/bmw+f800s
Jul 07, 2012 | BMW F 800 GS Motorcycles
How to remove front wheel bmw k100
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
BMW Service Front Wheel Removal Installation
BMW F800GS Maintenance Remove and install front wheel
http://www.k100.biz/pdf/OFF/K100_K75_2V_eng.pdf
Feb 16, 2012 | 1989 BMW K 100 RT
My 2000 650 dakar has 5000 miles with regular maintenance my problem is a flat spot in the power band around 5.5 rpm
the only way to fix the problem would be to upgrade your endcan or or carbs.it is a problem with all 650 dakers.just needs tunning up.hope this helps
Sep 25, 2009 | 2001 BMW F 650 Dakar
Front Brake Disk problem !
I can eard a metallic noise from the front wheel. Since 2 weeks I'm looking to find where he can come from and now I think I've found and I'm a little bit frightened. This noise is comming from the front break disk they are moving in the screw place. See the picture Have you ever see this problem ? Is it Normal ?,I think it's normal mate. Semi floating or floating discs are fitted so they do move. Someone more knowledgeable will be along soon I'm sure to confirm or correct me!,,,
Nov 10, 2008 | 2005 Aprilia Leonardo 300
Topcase Rack BMW F650GS, 08- & F800GS, 08- Logo
59 people viewed this question
Top Givi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Givi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
