Question about Karcher WV50 Window Vacuum
Water leaks from air vents - Karcher WV50 Window Vacuum
Bissell 9500 ProHeat, Why is it leaking water from the dry air vent?
The only thing I have seen cause anything like this is a high suds level in the waste water container. Usually caused by using pre cleaners on spots on the fabric. Those pr-ecleaners, i.e. Resolve, etc. create a LOT of excess suds in the waste water that can be sucked up in places they shouldn't be.
Jul 06, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why is my karcher wv50 blowing out water through its air vents
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Jul 31, 2014 | Karcher WV50 Window Vacuum
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
I replace the pump. How do i prime the pump?
Use a hose or bucket. Fill the pump body and the entire suction line (if possible) with water. Close all covers and keep the discharge of the pump open so it can vent any air. Once you are sure that the pump body is full, turn on the pump keeping the suction line under water.
Gary
Apr 19, 2011 | Bissell 8910 ProHeat Clear View Upright...
The Hoover Steamvac Widepath will NOT pick up water. The dispenser with cleaner DOES have water. The TANK that would receive the dirty water is NOT full. All tanks are on properly and the machine will...
Sounds like a clogged air path (no vacuum action) from the floor pick-up to the collection tank. Take the tanks off and deal with the vacuum problem alone. The collection tank should have a air exit vent--is it clear? Check the interior hose that you repaired--is it clogged? Remove the bottom plate and inspect the air path from it. Because this machine deals with water, clogs can become like concrete! Hope this helps!
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Nutone CV353 system in my utility room every time it
open a window, or the bathroom door if there is a vent in there it will draw in air from there, just be careful because if there is a bunch of dust up there it may fall out.
Jan 30, 2009 | Broan-NuTone CV353 Central Vacuum
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Karcher WV50 Window Vacuum Logo
37 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
