Question about Troy-Bilt Troy-Built Gas String Trimmer TB32EC
No start. If pull 300 times will seem like wants to. cleaned carb passages in and out, has spark and seems to have full compression. I give. TB32ec.
    Sergeant:
  • 337 Answers
Hi Scott try cleaning the air filter and then try running with just a small amount of fuel in the block itself. If it still wont run it's most probably the gaskets on the carb.
Posted on Oct 18, 2013
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2003 CRF150f that I can't get started.
As long as you have spark and compression i would go back to the carb and pull the low speed jet out make sure it is clear and also the passage way its in this is the most common problem if a bike sits for some time the gas tends to gel and the tiny jet will easily clog up make sure its clear or the bike just wot run correctly at all.
Aug 28, 2012 | Honda Motorcycles
Engine wont start it is getting spark and fuel any other reason why it won't start
You need 3 things for an engine to run; spark, fuel and compression. How is the compression? Is the spark plug new? If the plug is old, it could give a nice spark when you check it but have no spark under compression. Make sure the fuel you're using is fresh. If you give it a small shot of starting fluid and it fires up, your fuel delivery is suspect. In that case, you will need to remove the carb an THOROUGHLY clean it paying close attention to jets and passages. I always give people this warning: when cleaning jets and passages, NEVER use steel instruments. Use wood, copper wire or other materials that are softer than the material you're working on or you run the risk of ruining jets or even the entire carburetor.
Jun 27, 2011 | Suzuki SV 650 Motorcycles
I have a suzuki qaodrunner160 the motor terns over but wont start dont no howe to set timing up properly
The timing should not need to be adjusted. Most problems with the 160 Suzuki involve the carburetor. Make sure you have spark, pull the spark plug, hook the wire to it and ground the base against the engine. Crank the motor and see if the plug sparks. If it does, your problem is probably the carburetor. Pull the carb down and clean it. Pay special attention to the pilot jet and it's passages. Do not use wire to clean the jets and passages, use a spray carb cleaner and compressed air. Pay special attention to the passage in the float bowl that feeds the starter circuit. It will be a hole at the gasket edge of the float bowl that goes to the bottom of the bowl. There is a small orofice in that passage that is easily blocked, and when blocked, makes the engine real hard to start and keep running until the engine is warm. Good luck
Nov 06, 2010 | Suzuki DR 200 SE Motorcycles
It wontt start it has spark
There are only three things that your bike needs to start, Spark, Compression and Fuel, if you say that it has spark and compression then the problem has to be fuel, Make sure that there are no blockages in the line from the tank to the carb, if that is not the problem then you will have to pull the carb and clean out all the ports. I disassemble them as much as possible and empty a can of carb cleaner into a clean coffee can let it soak overnight and then blow out all passages with compressed air and reassemble. You should also pull off your reed cage and check to make sure that your reeds aren't cracked or broke. If your bike was runninng before and you give your carb a good cleaning and the reeds look good and it still doesn't work then you are going to have to look at the other two requirements, your spark should be a bright blue, if not try a spark plug first (you may want to try that before the carb cleaning) next you should get a compression tester and check the compression to make sure it is high enough. Your bike might feel like it has lots of compression but it might be low enough to make it hard to start.
Dec 09, 2009 | 2003 kawasaki KX 125
Can't keep running seems to flood out 1978/79 kawasaki
check the timing it sounds like your problem is there
Jan 13, 2009 | 1976 kawasaki KE 125
Stating pro
I hate to tell you this but, if the bike sat for a year with gas in it after the carb work, it'll likely need another carb cleaning. Crying or Very sad Over time, gas in the carbs turns to varnish and gum which clogs up the passages. What makes you think the starter is not working right, Kar? Does it sound funny, or what? About the compression test, you'll need a compression gauge - most automotive parts retailers have them. It's a small gauge with a flexible hose that you screw into the spark plug hole.
Nov 10, 2008 | 1996 Yamaha FZR 1000
Troy-Bilt Troy-Built Gas String Trimmer TB32EC Logo
398 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
