Question about Garden
Ryobi cs26 The string head is not turning. The shaft is turning upto the connection to the lower portion- where the curve in the shaft starts. After disconnecting the curved shaft and spinning the square pin by hand the string head does not turn. It seems there is a break between the square pin and the string head. Fixable?
    Sergeant:
  • 342 Answers
Mike it sounds like the head has sheared where it goes onto the shaft. You may be able to get the head off and see if there is any way of re attaching the shaft but it may be tricky. You could use the modelling clay that is also a resin that sets rock hard. (milliput) works for me.
Posted on Oct 19, 2013
#1 Taper
  • 1041 Answers
SOURCE: the trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
Posted on May 30, 2009
SOURCE: Stihl FS45 2 cycle string trimmer. Bought in 5/06
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Posted on Jun 24, 2009
  • 13 Answers
SOURCE: Weedeater starts fine but the string head will not
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Posted on Apr 16, 2010
wadembly
  • 513 Answers
SOURCE: How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Posted on Jun 28, 2010
panilling9
  • 284 Answers
SOURCE: Can't reassemble Ryobi cs26 string trimmer
https://pivotrim.com/
Posted on Jun 29, 2010
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
The lower shaft on my ryobi stoped turning, how do i fix this problem.
You didn't quite give me enough info on which machine you have ... but if it is one that allows the lower half of the shaft to be removed for using other implements, disconnect the shaft and try to turn the inner splined shaft by hand and see if the head turns, if not you may have a broken shaft cable or a frozen bearing in the shaft head...this will necessitate removal of the head and replacement of either the shaft cable or the machine head...if all is working then check the shaft going to the clutch...hope this helps... ;-D
Jul 13, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bought a Ryobi weed trimmer CS26 from Home Depot. The second time I used it string broke both ends. Could not take it apart went to Home depot after 30 days they could not take it apart. They would not...
just cheap equipment. Mark it up to experience and do not purchase equipment fro home center or box stores ever again.
This is just one of the many problems of dealing with
the box stores rather than a full service qualified dealer. If you can
find one in your area, patronize them. Not just when the box store
lets you down but for everything. These type dealers are
disappearing and are not being replaced and soon they will all be
gone.
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The string head does not spin as fast as the
it sounds like the centrifugal clutch is slipping. take it to several shops and get some quotes. Most times you'll find that fixing a Ryobi is more expensive than buying a bnew one.
Sep 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you remove the old string head to add replacement?
untwist the nut at the bottom of the spool head to replace the string
Aug 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 straight shaft. I can not get the string head off to replace the line.
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
31 cc Straight shaft/ head won't turn when connected and running
pull the shat off the engine and check the inner shaft it sounds like its stripped or the theengine side is cracked hope this helps
Oct 22, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
