Question about Itronix GoBook Q200 Pocket PC
Screen frozen how to soft reset
Start up frozen
hi try soft reset, go tomtom.com, select support, search reset, select soft reset, select your device, and do as told. good luck.
Feb 19, 2010 | Tomtom ONE GPS Receiver
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Jan 31, 2008 | Palm Tungsten T3 Handheld
My screen is frozen. How do you soft reset this phone.
Hello my friend,to perform a soft reset you pull out the stylus,remove the back cover.Use the stylus tip to press the RESET button located at the upper-left side of the open back panel,ifyour device restarts and displays the Home screen you can replace the back cover and insert the stylus back into its compartment.
Jan 20, 2010 | HTC Touch Pro2 Smartphone
Yesterday, when trying to send and receive email, i got the message "The remote party has ended this connection." Then today, screen started to freeze on text messages. Then finally, phone can't get...
It seems software problem.Try again reseting the device like that
You can reset your device’s settings and clear all added
data from memory.
Resetting the device
1. On the Home screen, press the Start soft key.
2. Select Settings → More... → Security → More... →
Reset.
3. Enter the reset password and press the Done soft key.
The default password is “0000.”
4. Press the Yes soft key to confirm the reset.
5. Press the Yes soft key to confirm deleting DRM files.
The device resets and reboots itself.
Jan 08, 2010 | Samsung Blackjack SGH-I607 Smartphone
HTC Touch Pro 2 - screen frozen - how to fix prob??
I have a similar problem with my HTC Touch Pro. A hard reset didn't work either!
Let us know if you get an answer!
Sep 22, 2009 | Computers & Internet
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Frozen screen and it says loader loading
just bellow wher it says Garmin there is a small notch...using flat screwdriver take the silver plate off...reset button on right.
Oct 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen ( palm powered)
Perform soft reset. If issue persist you may consider full reset
Nov 08, 2007 | Palm Tungsten T Handheld
Itronix GoBook Q200 Pocket PC Logo
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
justwinwin
ccsi99
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
