Question about Copystar "CS-5550ci Copier, Printer, Scanner, CS5550ci 55 ppm"
The machine has paper in tray one however it thinks it,s empty
    Master:
  • 552 Answers
Tray not closed properly, paper inserted improperly, sensing mechanism broken
Posted on Oct 20, 2013
Epson xp600 says paper tray is empty when its full
Not sure but there is usually a lever or pin that sits near the bottom of the paper tray to let the machine know that there is or isn't paper in the tray. It may have broken off or become dislodged?
Sep 10, 2014 | Epson Xp600 Expression Premium A4 Colour...
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Switching to paper tray 2
The machine will only switch to tray 2 IF BOTH TRAYS are set to the same paper size "OR" if the paper sizes are different, the machine will switch to the lower (14") tray when it recieves a document which is 14" long.
You may have the same paper in both trays.... but do you have them both programmed for the same size??? When you select the top and then the bottom tray are they saying they are the same size.????
Apr 17, 2009 | Muratec F320 Plain Paper LED Fax
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
HP laserjet 8000 tray 2 not empty
Do you hear the paper "drop" when you pull out the paper tray. If not, it could be a lift motor
You will have to pull the Paper Input Unit to repair it.
Small items are not available for us to purchase.
If you can't fix, you need a new unit. About $400.00
Feb 11, 2009 | HP LaserJet 8000 Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Xerox 6100 laser - paper jams if paper tray low on paper
There could be two things. First, be sure the paper tray is not binding. The metal plate in the middle should spring up easily. The friction pad should be firmly attached to the tray, but not extending over the metal portion. The second thing would be to clean or replace the feed rollers. They are inside the machine above where the tray would sit. Since the tray feeds when full, I don't think you have a clutch problem. Let me know how it goes.
Jun 10, 2008 | Xerox 6100/DN Laser Printer
Cancel incoming fax's
take the paper out of the tray, unplug the machine. while holding down the stop/exit button, plug it back in. good luck!
Apr 29, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Copystar "CS-5550ci Copier, Printer, Scanner, CS5550ci 55 ppm" Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
