Question about Plumbing
Can a defective Rohl apron front sink be pulled and reinstalled?
  • Carmen Sandiego
    Carmen Sandiego Jan 30, 2014
    I'm not much of a fix it person. Usually I do more harm than good, so whenever I need my sinks or toilets fixed I just call in the professionals. Usually I call plumbers albuquerque nm.
    Problem Solver:
  • 8 Answers
Generally these sinks are placed into the cabinet in a cradle and then the countertop material is set "over" them for an undermount look. To remove the sink you would need to cut the front of the cabinet and also remove the cradle to drop it down and out, the only other way would be to lift off the countertops, which may not be possible depending on seams and if tile backsplashes are already installed.
Posted on Dec 10, 2013
2 Suggested Answers
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
We had to replace the flex hose on our Rohl LS57 and now each time the water flow is turned off the pull out head "walks" out a little bit more. The weight was correctly reattached. Ideas?
If the weight is moving you can get a section of rubber tube or if you have an old hose that will work as well. Remove the weight and mark where you want it. Slice one side of the tube and wrap it around the flex hose and reinstall your weight. This should stop it from sliding.
Sep 16, 2017 | Rohl Plumbing
I have a rohl model r77v3 faucet. is it supposed to rotate on o ring on top of counter? or on the base ring?
All the info is here. Trim Ring, O-ring, Counter.
[PDF]R77V3 (Metal Lever) R77V3LP (Porcelain Lever) - Rohl www.rohlhome.com/pdf/R77V3.pdf
  1. Cached
  2. Similar
R77V3 (Metal Lever). R77V3LP (Porcelain Lever) www.rohlhome.com. Consult your local ROHL showroom for additional information and specifications.
[PDF]ROH8734 Maint Bro_f.qxd - Rohl
https://www.rohlhome.com/pdf/489.pdf
  1. Cached
R77V3 (Metal Lever) www.rohlhome.com ... For complete warranty details and a list of showrooms, go to www.rohlhome.com. ... NOTE: MODELS MAY VARY ...
Rohl R77V3 Single Lever Pull-Out Kitchen Faucet with Metal Lever ...
https://www.ajmadison.com > Sinks & Faucets > Faucets > Pull-Out
  1. Cached
Rating: 3 - ‎3 reviews Brand: Rohl. Series: Country Collection. Model: R77V3. Dimensions. Faucet Height: 8 1/2 Inch. Faucet Reach: 9 Inch. Base Width: 2 3/8 Inch. Cutout Size: 1 3/8 ...
rohl model r77v3 Google Search
Dec 02, 2016 | Rohl Plumbing
How do I secure my Rohl "country bath" drain to the sink?
That drain sounds about normal, Dave. What sink are you trying to attach it to? That sink may require a special drain.
The square holes are for the overflow, which takes water in at the overflow port (usually under the front edge of the sink) and routes that water under the bowl - the bowl usually has two layers - to the square holes, where it turns & goes down the pipe. If your sink has no overflow, there won't be a second layer for the bowl, and that drain won't work.
Aug 02, 2014 | Rohl Plumbing
I have a leak coming out of the hole in the base of a Rohl pull-out faucet.
sounds like there's a kink in the line leading in,find the kink & unkink it,should help
Dec 08, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
Water won't come thru the faucet.
dirt in the screen before the sprayed handle, shut off vakve clogged under sink, is this something that just happened? where is the check valve located is it in the hand held or under the sink,, if in the hand held take a needle and clean it out, or call the company and have them send out a new one
May 30, 2009 | Plumbing
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Nov 06, 2008 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Plumbing Logo
88 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
