Question about Rohl Shaws Original Fireclay Apron Front Fire Sink RC3618
Rohl r77v3 I have a rohl shaw sink that has crazing and would like to have it pulled and replaced. Is this possible? It was installed two years ago with a total kitchen remodel.
5 Suggested Answers
  • 29 Answers
SOURCE: Can a chip in a Rohl shaw fireclay apron sink be
yes with epoxy
Posted on Jul 21, 2009
  • 234 Answers
SOURCE: I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
Posted on Jan 16, 2010
packrat1948
  • 528 Answers
SOURCE: The spigot on my my bar sink Rohl Country Kitchen
That is an internal failure of the faucet and you will need to contact Rohl for a possible warranty replacement.
Posted on Mar 05, 2011
  • 11 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
call ROHL at 800.777.9762 and request a new Cartridge. They will ship it at no charge.
Posted on Dec 18, 2014
I have a rohl model r77v3 faucet. is it supposed to rotate on o ring on top of counter? or on the base ring?
All the info is here. Trim Ring, O-ring, Counter.
[PDF]R77V3 (Metal Lever) R77V3LP (Porcelain Lever) - Rohl www.rohlhome.com/pdf/R77V3.pdf
  1. Cached
  2. Similar
R77V3 (Metal Lever). R77V3LP (Porcelain Lever) www.rohlhome.com. Consult your local ROHL showroom for additional information and specifications.
[PDF]ROH8734 Maint Bro_f.qxd - Rohl
https://www.rohlhome.com/pdf/489.pdf
  1. Cached
R77V3 (Metal Lever) www.rohlhome.com ... For complete warranty details and a list of showrooms, go to www.rohlhome.com. ... NOTE: MODELS MAY VARY ...
Rohl R77V3 Single Lever Pull-Out Kitchen Faucet with Metal Lever ...
https://www.ajmadison.com > Sinks & Faucets > Faucets > Pull-Out
  1. Cached
Rating: 3 - ‎3 reviews Brand: Rohl. Series: Country Collection. Model: R77V3. Dimensions. Faucet Height: 8 1/2 Inch. Faucet Reach: 9 Inch. Base Width: 2 3/8 Inch. Cutout Size: 1 3/8 ...
rohl model r77v3 Google Search
Dec 02, 2016 | Rohl Plumbing
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
How do I secure my Rohl "country bath" drain to the sink?
That drain sounds about normal, Dave. What sink are you trying to attach it to? That sink may require a special drain.
The square holes are for the overflow, which takes water in at the overflow port (usually under the front edge of the sink) and routes that water under the bowl - the bowl usually has two layers - to the square holes, where it turns & goes down the pipe. If your sink has no overflow, there won't be a second layer for the bowl, and that drain won't work.
Aug 02, 2014 | Rohl Plumbing
Can a defective Rohl apron front sink be pulled and reinstalled?
Generally these sinks are placed into the cabinet in a cradle and then the countertop material is set "over" them for an undermount look. To remove the sink you would need to cut the front of the cabinet and also remove the cradle to drop it down and out, the only other way would be to lift off the countertops, which may not be possible depending on seams and if tile backsplashes are already installed.
Oct 18, 2013 | Plumbing
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
Mar 03, 2012 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Jan 16, 2010 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Nov 06, 2008 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Rohl Shaws Original Fireclay Apron Front Fire Sink RC3618 Logo
50 people viewed this question
Top Rohl Home Experts
Donni Steen
Tom Chichester
Are you a Rohl Home Expert? Answer questions, earn points and help others
