Question about Yamaha RX-V661 Receiver
No sound from zone 2 speakers on yamaha rx-v661
    Genius:
  • Yamaha Master
  • 1,054 Answers
Have you gone into the speaker configuration menu and turned on zone 2?
Posted on Oct 18, 2013
Testimonial: "I have done that and still nothing. Any other suggestions?"
SOURCE: Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Posted on Dec 05, 2007
  • 151 Answers
SOURCE: I have an rx-v661 when
Go back into zone 2 set up and turn volume fix off then turn up volume for zone 2.
hope this helps.
CABLE GUY.
Posted on Jul 02, 2008
SOURCE: yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Posted on Apr 03, 2009
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
  • 8 Answers
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Posted on Sep 07, 2009
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
No volume in Zone 2
Sep 05, 2009 | Yamaha RX-V661 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
NO sound on Zone 2
Did you use the same terminals or two different ones to make the connections?
May 18, 2008 | Yamaha RX-V661 Receiver
Cannot figure all of the setup instructions
is your problem setting up? connecting the speakers and sources or you have made the speaker connections but to make it sound is your problem... pleased let me know.
Mar 31, 2008 | Yamaha RX-V661 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
115 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
