Question about managemylife.com
My garage door stops erratically when operated from remote or wired switch. I have cleaned the lenses on the sensors, tried adjusting the limit switches. I have no trouble faults on the LED light. The overhead light comes on when the unit is activated then goes off when the door stops.
  • 90 Answers
See that the screws that fasten the wires going between the main unit and the sensors are tight. They tend to get loose at the sensors due to vibrating of the door rails.
Track the wires and tighten the screws at the sensors and at the main unit.
No need to power off the system, the voltage at the sensors is low (12V)
Posted on Oct 18, 2013
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
I save a Sears HBW0777 garage door opener. When I click my remote to open it, it moves for a second then I hear the opener clicking. The same sound when something is in the way of the door. If I hold...
Unhooking the wires disconnected the safety sensors completely. The safety sensors are required to close the door. Both lights should be on, the lenses should be able to see each other clearly, and the wires between the sensors and the opener must be intact, in order for the system to function properly. Reconnect the wires to the opener, adjust the aim of the sensors, ensure there is no debris in the sensor lenses, and if it still doesn't work, you'll need a set of replacement sensors.
Aug 23, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster garage door that doesn't work. When I hit the button it clicks and the motor spins maybe two turns. All my safety sensors are lit. I know this isn't the problem. However after further...
YOU COULD TRY
RECONNECT THE RPM SENSOR, UNPLUG THE UNIT. TURN THE MOTOR BY HAND (DOWN DIRRECTION) TO CLEAR THE LIMIT SWITCH.
PLUG THE UNIT IN IF. IT STILL OVERSHOOTS THE LIMIT IT COULD BE A BAD LIMIT SWITCH. IF THE SWITCH TESTS GOOD FOR CONTINUITY REPLACE THE BOARD.
HOPE THIS HELPS
Jun 03, 2010 | liftmaster Chamberlain Garage Door Opener...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door goes up, Won't go down.
It sounds like the limits are out of adjustment. With the door down, rotate the down limit until it clicks. Then raise the door manually, and set the up limit until it clicks. You should be able to hear the switch 'click' when it activates. Pay attention to which way the plastic nuts are moving on the screw going up and down. That way you know which way to turn them to set it.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman chain drive opener won't stay down
Check the down limit:
If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing the garage door).
Check the up and down force:
On your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't stay closed
Jan 03, 2009 | Electrical Supplies
Liftmaster garage door opener problem
stop adjusting. you are doing right thing. unit will not run down w/o eyes so removing wiring did nothing. you gave clue when yu said they were folloded. buy new set of eyes.
Oct 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
managemylife.com Logo
41 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
