Question about Gestetner Office Equipment & Supplies
Gestetner 3225 copier, "document feed door/cover open" any ideas?
  • 3 Answers
Check the DF door switch or sensor
Posted on Oct 19, 2013
  • 37 Answers
SOURCE: Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Posted on Nov 22, 2007
SOURCE: Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Posted on Jul 09, 2008
  • 37 Answers
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Posted on Aug 14, 2008
SOURCE: display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
SOURCE: Problem with Aficio 450 door cover sensors
I post a solution for this problem see: www.fixya.com/support/t2748127-false_door_open_reading_aficio_350
Posted on Sep 22, 2009
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
Tip
ERROR codes Canon 3225
Canon 3225 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
I have a misfeed in my copier. I have cleared all the channels but it still shows up on the board as a misfeed.
Hello !
when you will open all doors too remove the miss feed usually people forget one door to open let say this way. You will open the front door than you will open the duplex unit (if ti has one), than you will open the cover after the duplex usually here is the miss feed revolve the blue colored wheel in the front of the machine if you need to output the miss feed paper and than before you close all doors do not forget to open the door named [C] which is located under the fusing unit or under the yellow warning sign where writes something like " caution heat area please be careful to not burn your fingers" or something like that the door is opened by putting your fingers under the letter [C] and pull it your fingers towards you. Than you can close all the doors and the miss feed will reset.
Please rate the post if was helpful or write again for i to be able to post some other information
Regards
Dec 31, 2009 | Gestetner DSc224 Copier
Paper is getting jammed in the document feeder
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Aug 12, 2009 | Gestetner - DSm675sp Digital Imaging...
Where is the plotter cover on the gestetner
The plotter cover is the piece that you press down when installing a new roll of masters. it is located on the top right of the machine.
Sep 04, 2008 | Gestetner - 5309L CopyPrinter Copier
Gestetner 3225
-Definition- [B]
- Possible causes -
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Gestetner DSC530 -- Auto Document Feeder
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Dec 13, 2007 | Gestetner DSC530 All-In-One Laser Printer
Gestetner 3225
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
