Question about Poulan Garden
Which brands of deck belts are compatible with a poulon deck belt PO14538
  • 86 Answers
SOURCE: replace deck belt instructions.
A yard machine is made by mtd,if you have a computer you can do a google search on your yardmachine model to get diagram
Posted on May 12, 2009
wadembly
  • 448 Answers
SOURCE: I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Posted on Jun 08, 2009
lester482529
  • 226 Answers
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Posted on Jul 03, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
How do I drop the deck on a 42 inch riding Poulon lawn mower
Look to each side of the deck just in front of the rear tires. You will see an spring clip on each side. Remove these clips. There is also a clip on the front of the deck, remove it as well. Remove the belt and the deck will slide out from under the tractor.
Mar 09, 2017 | Garden
The belt on my Pioneer CT-9R has slipped off the left hand side flywheel. Can the belt be repositioned easily or do I need to see professional help?
If it has slipped off then the belt is too loose so you will need to replace it. Too many people try and put ONLY a new belt on and forget all the rest of the work a deck needs. They are only successful for a very short time if at all. I have been working on tape decks for 45 years and have seen just about all brands. Look for a shop that specializes in tape deck repair.
Feb 11, 2014 | Audio Players & Recorders
Where can I obtain the large round drive belt for MR929 tape recorder
I am not famailiar with this deck model but if you know the brand name you might be able to search for the belt at Marr Communications where Fred sells belt kits.
http://marrscommunications.com/
Feb 06, 2013 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I need a diagram of the drive belt and blade belts. How they run above the deck.
Ok.... I have to guess what mower you have. I am going to pass a deck belt link below. The first pitcures that will come up are for John Deere. At the top of the page you will see brands with links to the belt routing. Click on the brand name for your mower and then locate your deck.
John Deere http://opebycrigby.tripod.com/decks/jddeck.html
MTD http://opebycrigby.tripod.com/decks/mtddeck.html
Murray: http://opebycrigby.tripod.com/decks/murdeck.html
The MTD and JD links have most deck belt routing pictures that can equate to other brands.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
Keeps shutting down after 20 minutes
hi
1 reason could be belt and deck(motor draws a lot of amps and belt and deck heats the motor up)
just try wax or libricate compatible lube and try (belt and deck lube you can buy from gympart.com
Nov 21, 2010 | Life Fitness T3 Treadmill with Advanced...
Need the short, "mode belt" for my TC-K611S tape deck
As long as it is the same thickness as yours the 19mm will be about right.
Belts are universal used on many brands.
Dec 19, 2009 | Sony CASSETTE DECK Single Dual Cassette...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
18 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
