Question about A.C.T ATV Tire - 26x8R12
My tires are 26x10r12.made in 2007,buy new in may 2009,all the side lugs have a one inches crack on sole along the lug.these tire have only ten purcent of use and the time my mule 610 is store in my garage,[no sun).Same for my brother with same tire.i things it is a product problem.what i made with compagnie.Thanks.
    Master:
  • 492 Answers
Rubber breaks down after 5-6 years regardless of use.
Posted on Oct 18, 2013
How do I change rear tire on a 1999 trooper
Break lugs loose first. Chock opposite front wheel Jack upwhere the sprng meets up to the frame in fornt of the tire. Raise vehicle until tire is free by about 1 inch. Remove lugs swap with spare. Snug lugs then lower trie and then tighten lugs. put jack and chock away. That should take care of it.
Sep 26, 2014 | 1999 Isuzu Trooper
Instructions on changing front brakes on a 1993 delta88 oldsmobile 1993
Instructions
    • 1Loosen the lugs nuts using the tire iron. Place the wood blocks in front of the tires you will not be removing.
    • 2 Raise the vehicle using the floor jack. Set the jack beneath the support strut that runs along the outer edge of the undercarriage. Raise it enough to allow the tires to clear the ground. Place the jack stands underneath the same strut as the jack.
    • 3 Remove the lugs nuts completely and take the tire off. Set these all aside.
    • 4 Remove the mounting bracket bolts with a socket wrench. The mounting bracket is the metal half-circle that is revealed when you remove the tire. Tie the mounting bracket to the undercarriage with rope to prevent stress damage to the brake line.
    • 5 Remove the brake pads from the bracket by hand.
    • 6 Compress the caliper cylinder with the C-clamp. The caliper cylinder is the 3- to 6-inch wide cylinder in the center of the bracket. Make sure that it is flush with the bracket.
    • 7 Install the new brake pads where the old ones were.
    • 8 Reattach the mounting bracket to the rotor. Reattach the tire and finger-tighten the lug nuts. Lower the vehicle and the tighten all of the nuts with the tire iron.
Apr 08, 2014 | 1989 Oldsmobile Delta 88
Crack along lug of tire
If it's an old tire, the crack is probably caused by the rubber drying out and becoming brittle. If it's a new tire, it sounds like a manufacturing defect or road damage.
Oct 18, 2013 | A.C.T ATV Tire - 26x8R12
1996 buick take off my front tires
remove wheel cover then with tire on the ground just loosen lug nuts just a little dont remove lug nuts then safely raise support vechicle.then remove front tires.
Apr 07, 2013 | 1991 Buick Century
How to get tire off when missing tire key
on most lock lugs, a socket can be knocked onto the lug, in other cases use a hammer and a chisel. hit the lug dead center and the lug will crack. if you dont want to ruin the lug, find a tire shop or a place that sells rims and rim accesories
May 24, 2012 | 2000 Lexus RX 300
I was changing front passenger side tire when lug nuts snapped bolt off. How do I change lug bolts out to new one. Plan to change all for bolts and lug nuts for this tire.
take tire off, take brake caliper off, remove rotor, take nut and bearing off, then hammer out old studs and hammer in new ones. Tim
May 29, 2011 | 2003 Kia Spectra
How do u chage tire on a 2007 bmw 650i
block wheel on opposing side to avoid rolling.loosen lug bolts on wheel using lug wrench. donot completely remove nuts. place jack at designated position on side of car. diagram should be on spare cover in trunk under carpet along with the appropriate tools.raise vehicle with jack just high enough to clear ground. remove nuts and flat tire and replace with spare. tightened lug nuts and lower jack. check nuts again for tightness.
Apr 26, 2010 | 2007 BMW 650i Convertible
Back Wheel is Walbing
Are the wheels lugs tightened? If so then its probably the wheel bearing or the tire is bad.
Jan 06, 2010 | 2002 Mercury Mountaineer
Broke off lug nut while changing a rear tire
You will have to remove the brake drum or rotor if it has disc brakes and drive the broken lug out of the drum or rotor. Purchase a new lug from any auto parts store buying the exact same size and drive the new one in. Reinstall the tire/wheel and torque the lug nuts to 100 lb/ft with a torque wrench.
Oct 28, 2009 | 1991 Ford Taurus
How to get a tire off of my car.
Make sure the car is on a good jack (not a bumper jack) use an old wheel and tire as a safety under the chassis if you must. Spray lube into the lug holes that go through the wheel and let it run down to the center hub. then use a sledge hammer, steel pipe or good baseball bat and give the tire (not the wheel) a good shot on the side. Nine out of ten times it will come off. If not, put the lugs back on leaving them about 1/2" from the wheel, put the car on the ground, start it and turn the steering back and forth.
Good luck
Sep 25, 2009 | 2001 Hyundai Tiburon
A.C.T ATV Tire - 26x8R12 Logo
55 people viewed this question
Top Carlisle Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Carlisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
