Question about Apple iPad Tablets & eReaders
After a system upgrade my ipad 2 now requires a passcode which i have never had before. How do i get past it?
  • 3 Answers
Forgot patter on my tablet polaroid pmid706 need help
Posted on Oct 18, 2013
3 Suggested Answers
atptsoi
  • 137 Answers
SOURCE: forgot restriction passcode on apple iPad 2
There is no way to unlock it as a passcode also prevents other people from unlocking it to access your data. What you could do is put it into recovery mode and then do a restore which will wipe all data, assuming you have a backup, you can just restore the data.
Posted on Nov 03, 2012
  • 32 Answers
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
Posted on Aug 27, 2012
Passcode is required to enable Touch ID on Ipad
This is plain and simple - you need the original passcode before you can add your fingerprint. If this was a used tablet - you can get the passcode from someone that has it - or you may be able to factory reset it using itunes and recovery mode.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Apr 27, 2017 | Tablets & eReaders
I need to get rid of my passcode on my ipad 9.7 pro and my iphone 7plus i need help asap thank you
You can remove passcode from iPad by restoring your device with iTunes.
Step 1. If you've matched up your iPad with iTunes, you can reestablish your device.
Step 2. Associate your gadget to the PC you matched up with.
Step 3. Open iTunes. On the off chance that requested a password, attempt another PC you've synchronized with, or utilize recuperation mode.
Sit tight for iTunes to match up your iPad and make reinforcement.
Once the synchronization and reinforcement have finished, click Restore. After clicking Restore, you have successfully remove iPad passcode with iTunes.
How to Remove Passcode from iPhone
Mar 27, 2017 | Tablets & eReaders
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Nov 23, 2016 | Apple iPad Tablets & eReaders
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Ipad A1396 is disabled its sayes to connect to itunes but itune
The intent is to connect your iPad to a computer that is running iTunes.
You must have a current version of iTunes that knows about iPads and an operating system that can run the current iTunes. If your need to upgrade, be sure to install the OS first before your install the iTunes.
Apr 03, 2015 | Apple iPad 2 Wifi 16GB
How to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
Dec 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
What will happen if i hit the reset button on my ipad 2?
What iOS are you running?, and how much free space you have?
iOS 7 requires 2.5 gigs free space. Then update via Itunes on your computer or wifi. if it's the original ipad it maxes out to iOS 5.1.1.
Jul 20, 2014 | Apple iPad 2 Wifi 16GB
Forgot restriction passcode on apple iPad 2
Nov 03, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
88 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
