Hotpoint aqualtis aqxxl129pm washing machine noisy during spin
  • 32 Answers
SOURCE: Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Posted on Feb 12, 2009
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Posted on May 27, 2009
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
Posted on Jun 28, 2010
Aqualtis washing machine has error code F01 what does this mean?
F01 Electronic circuit board fault
Issue: Washing machine is not operating - some or all functions are not selectable.
Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
How do i unlock the door manually it's locked with the washing inside
do you have the manual I found this answer but have no idea if your machine is like the one described .Then opened the door (if locked use yellow tab behind kicked panel to open
Feb 19, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
?I canot use my washmashine because it doesnt strart ,only are flashes of the lights and nothing else
This model of Aqualtis machine is about 8 years old, I am surprised its lasted as lon, I would suggest the main board has gone, you could try picking one up on EBay for about £35, but i wouldn't waste any more money than that.
Nov 06, 2014 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Water pump in the bottom of unit is about to quit all together.might want to get model and serial number go online get factory replacement water pump for that unit. Sorry....
May 17, 2014 | Washing Machines
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Washing Machines Logo
Top Washing Machines Experts
